| Ragdoll |
 Ragdoll Spanner Monkey
 Posted: 14:02 - 29 Nov 2005 Post subject: Bikers who also drive cars - your help please |
After having had a "word of advice" from my OH, I have started questioning the way I ride. I change gear the same I would if I was driving, but he has said that I am not using the gears to their best advantage. I'm asking as I started having problems changing down through the gears as they weren't engaging. He said it's cos the revs aren't high enough, so I've tried revving the whatsits off her and then changing down but it's not helping...any advice? (other than "you're a girly, what do you expect?" ) ____________________ 1st bike - Honda Rebel; 2nd bike - CBR125; next bike - husband's 'blade hehehehe
Lancashire Bikers Facebook Group |
| lumphammer |
 lumphammer Trackday Trickster
| DucatiEVO |
 DucatiEVO Could Be A Chat Bot
 Posted: 14:15 - 29 Nov 2005 Post subject: |
Revs got nothing to do with how the gears work (assuming you're not doing like 500rpm etc), that's why there is a clutch
If you've just started having problems changing down, perhaps there is something else at fault, clutch/chain adjustment etc.
Have someone else ride the bike and see if they enounter the same problem, if not you know it's something your doing (or not) and can then work on that area.
 ____________________ aKa: Ducky |
| yambabe |
 yambabe World Chat Champion
 Posted: 14:28 - 29 Nov 2005 Post subject: |
I think I know what he's getting at.
In the car, your gear changes are very "definite", clutch down & power off, change, clutch up & power on and down to a certain (very slow creeping) point you pretty much control your speed by your revs.
On the bike, especially at low speeds and when I am changing gear a lot, I tend to control my speed much more by slipping the clutch (keeping it just around the biting point rather than fully open) and keeping the revs constant. ____________________ Sod falling in love, I wanna fall in chocolate.  |
| Ragdoll |
 Posted: 15:57 - 29 Nov 2005 Post subject: |
He said it was OK when he was riding it (please bear in mind he can't drive a car so can't compare). He said the only way he could replicate the problem was by being in too high a gear when changing down. The only way I can describe it is like having something stuck under the gearstick that won't allow the gear to click into place when changing down. It only started happening yesterday and I wondered if I was just getting too cocky and my riding had gone crap It's fine changing up the gears  ____________________ 1st bike - Honda Rebel; 2nd bike - CBR125; next bike - husband's 'blade hehehehe
| lumphammer |
 Posted: 20:35 - 29 Nov 2005 Post subject: |
Sounds like the clutch is either dragging or not disengaging properly. Could do with a check on the adjustment. I would not have thought that your riding could change overnight.
My problem is that I am having trouble getting used to slipping the clutch - something which you don't do on a car (unless you like the smell of burning clutch plate ) |
| BlackSheep |
 BlackSheep Trackday Trickster
| Ragdoll |
 Posted: 11:47 - 30 Nov 2005 Post subject: |
Slapped a load of WD40 on it last night (the gear stick) and it seems to have helped
Thanks everyone for your advice!  ____________________ 1st bike - Honda Rebel; 2nd bike - CBR125; next bike - husband's 'blade hehehehe
| Trixie |
 Trixie World Chat Champion
 Posted: 23:51 - 30 Nov 2005 Post subject: |
Check your chain adjustment as well, I've been getting a similar problem when changing down on my bike, and it's cos the chain was a bit loose.
As far as gear changes on a bike vs a car are concerned, the amount of revs you give a bike as opposed to a car will be different, and it's easier to do clutchless upchanges on a bike, but as long as you're smooth and making good progress (and you haven't blown the gearbox up!) then I don't really see a problem!  ____________________ Dead nobodies in company cars... |
| Ragdoll |
 Posted: 09:15 - 01 Dec 2005 Post subject: |
Thanks Trixie. Took her out for a longer run last night rather than just pootling to work and back and she's running just fine now. Don't you just love WD40?  ____________________ 1st bike - Honda Rebel; 2nd bike - CBR125; next bike - husband's 'blade hehehehe
| ISLAND GIRL |
 ISLAND GIRL World Chat Champion
 Posted: 14:16 - 01 Dec 2005 Post subject: |
Ragdoll, I change gear much the same as I do when driving, just by listening to the sound of the engine and have no problems with it, becuase I am a driver too I soon picked up the gear changing on a bike  |
| Ragdoll |
| map |
 map Mr Calendar
 Posted: 15:51 - 01 Dec 2005 Post subject: |
FWIW one of my friends is a (car) driving instructor. She tells her pupils when lifting the clutch do it so it's fully up in a slowish count of 2 (as in 1.....2).
Try this sort of thing on the bike, from fully disengaged (lever in) to fully engaged (lever out) in a count of 2. I've tried it and it does make a difference (less snatchy if that's a word ).
Just my thoughts  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| impaler |
 impaler Crazy Courier
 Posted: 13:51 - 02 Dec 2005 Post subject: |
| Ragdoll wrote: | | ISLAND GIRL wrote: | Ragdoll, I change gear much the same as I do when driving, just by listening to the sound of the engine and have no problems with it, becuase I am a driver too I soon picked up the gear changing on a bike  |
I was the same and thought I was doing OK and always thought OH used to rev the bollox off his bike but he told me it was the right way to ride a bike!  |
I had a car licence for quite a while before learning to ride and I found I had the same problem, to a certain extent - you learn to associate a certain car engine pitch with the time you should be changing up.
Say that pitch was at 4000rpm in a car with a 6000rpm redline, you'd be two-thirds of the way through the rev range. My Bandit has a 12000rpm redline, so if I changed up at 4000rpm (as my ears were telling my brain to do) that would only be one-third of the way up the rev range - in fact, the Bandit only really starts pulling properly at 6000rpm, so listening to your car-tuned ears would mean you'd only be using a tiny fraction of the bike's power.
Even just travelling around town relatively slowly, you should expect to hear an engine pitch from the bike that would have your car spitting pistons  ____________________ Monster m600
Web, blog, Bikepics page
An optimist will tell you the glass is half full. The pessimist, half empty. The engineer will tell you the glass is twice the size it needs to be. |
| Ragdoll |
 Posted: 21:59 - 02 Dec 2005 Post subject: |
we just had this conversation again. He said "Don't listen to it like you would a car" and I told him to shut up, I was doing just fine now!  ____________________ 1st bike - Honda Rebel; 2nd bike - CBR125; next bike - husband's 'blade hehehehe
| Barker-CBR 600 |
 Barker-CBR 600 Could Be A Chat Bot
| Ragdoll |
 Posted: 22:05 - 04 Dec 2005 Post subject: |
Yeah, you're right. I've been riding that way since I posted and can definitely feel a difference. Thanks  ____________________ 1st bike - Honda Rebel; 2nd bike - CBR125; next bike - husband's 'blade hehehehe
| lumphammer |
| yambabe |
 Posted: 00:51 - 05 Dec 2005 Post subject: |
Just to throw a cat amongst the pigeons:
My bike hasn't got a rev counter so I always change up/down by engine sound. Isn't that better once you're used to your own bike? ____________________ Sod falling in love, I wanna fall in chocolate.  |
| mchaggis |
 mchaggis World Chat Champion
| Barker-CBR 600 |
 Posted: 02:09 - 05 Dec 2005 Post subject: |
I rode a cruiser without a taco as well. And of course cant do anything except ride by your ears (and maybe on a cruiser the vibrations! lol)
Still i imagine i wasnt revving it high as i really should have been, but if it aint broke dont fix it.
 ____________________ Previous - Gilera DNA50 / XVS125 Dragstar/Honda CBR 600F/GSF 650 Bandit
Current - 2013 Suzuki VZ800 Intruder
'Is this a rhetorical question?' |
| Annabella |
 Annabella Like a person, only smaller
 Posted: 15:20 - 05 Dec 2005 Post subject: |
When you're changing down, the aim is to match your revs in the current gear to what they will be when you hit the next one.
So pull the clutch in, blip the throttle to match the revs you will want next, then change gear.
Rather than the car way where you lift your foot off the throttle completely before you change down. ____________________ Avast! Pirates ahoy!
I did Cadwell!
www.bikepics.com/members/bella |
The last post was made 20 years, 315 days ago. Instead of replying here, would creating a new thread be more useful? |
