| siddiqi |
 siddiqi L Plate Warrior
| bidman |
 bidman Crazy Courier
 Posted: 22:13 - 01 Dec 2005 Post subject: |
Make sure that the gear lever isn't catching on the frame stopping it from goin up far enough to engage 2nd gear or neutral, if so just undo it move it round a notch and slide it back on a spline less so it sits further down giving you more room to click up into gear. Let me know how it goes , Dan ____________________ Don't ride it, RAG IT!! |
| siddiqi |
| bidman |
 Posted: 22:34 - 01 Dec 2005 Post subject: |
Does sound like it could be the gearbox if its jamming inside, try moving the splined selector rod in and out as it could be that it has been dropped and the rod has been forced inside the gearbox moving the gear up the shaft meaning it will only select gear in a certain position. Have a play around with what you can see on the outside see if you can find anything , Dan ____________________ Don't ride it, RAG IT!! |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 00:38 - 02 Dec 2005 Post subject: |
The clutch is probably out of adjustment, so it is still applying a torque to the drivetrain with the clutch pulled in. If you adjust the cable at the top end (for minor adjustment) and/ or at the bottom end (for major adjustment) so that it is tighter, the clutch should have a greater disengagement when you pull the lever in to the bar.
I believe the actuating arm (at the bottom end of the cable) should be at 90 degrees to the fore-aft axis of the bike when the lever is out, assuming the clutch isn't worn out. At 1600 miles, it really shouldn't be, and gearbox damage isn't especially likely.
Also try rocking the bike back and forth after you've come to a standstill to persuade the clutch to disengage properly and neutral to select more easily. Gear selection problems are usually an indicator of low or old engine oil, or of an ill-adjusted clutch. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| instigator |
 instigator Super Spammer
 Posted: 00:46 - 02 Dec 2005 Post subject: |
Common problem with the GT250 gearbox. Go to Yahoo and do a search for the comet owners group or 25 owners group. Very helpful bunch. Most are from Korea or thereabouts but speak/translate in English.  |
| map |
 map Mr Calendar
 Posted: 10:13 - 02 Dec 2005 Post subject: |
Go with the search for user groups to get the best info.
However, FWIW, this can also be caused by too much oil. Usually this is when topping up the oil before it has chance to get to the sump so you get a true reading. Had this once, went for a longish ride and couldn't get neutral at the end of it. Sorted by a change of oil (measuring quantity that went in from user manual/engine markings).
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| bidman |
| siddiqi |
 Posted: 13:59 - 02 Dec 2005 Post subject: |
The gear shift isn't moving at all... well very slighty. Nowhere near as much as it would have to move to change gear.
Thanks for all your advice. I will be having a tinker after work tonight.
Not quite sure what a splined selector rod is - but I will look out for it! Ahhh the joy of tinkering with machinery you know nothing about
Sarah
x |
| DM |
 DM Scooby Slapper
| bidman |
| siddiqi |
 Posted: 23:32 - 02 Dec 2005 Post subject: |
Success
I have adjusted the clutch and now everything is working fine.
Thanks to everyone for all the advice, much appreciated.... and I now know what a splined selector rod is
Hurrah
. . .x Sarah x. . . |
| bidman |
 Posted: 23:36 - 02 Dec 2005 Post subject: |
Nice 1  ____________________ Don't ride it, RAG IT!! |
The last post was made 20 years, 261 days ago. Instead of replying here, would creating a new thread be more useful? |
