Bastard fairing bolts
The Tot
PostPosted: 13:55 - 03 Dec 2005    Post subject: Bastard fairing bolts Reply with quote
I need to do an oil change but i've noticed that my fairing bolts are being right bitches. You have a couple that are fine, but the rest are complete bitches. They require a philipshead screw, but they have been rounded off. And they're situated pretty deep. So has anybody got suggestions on how to get them off. Usual tools in the garage + dremel.
Never argue with autism
Quote Me Happy
PostPosted: 14:03 - 03 Dec 2005    Post subject: Reply with quote
If you have a dremel can you score a cross into the bolts so you can use the screwdriver?
Razzy
PostPosted: 14:17 - 03 Dec 2005    Post subject: Reply with quote
failing that then weld a nut or something on and take it off that way.
GSX 1400 K5 SOLD
Tiger 955i SOLD
R.I.P Aprilia RSV 1000r 9/2/09
The Tot
PostPosted: 14:18 - 03 Dec 2005    Post subject: Reply with quote
The problem's with the lowest of the fairing bolts wich mounts onto the V-plate, where the left and right side join, just below the rad. The bolt is recessed by about 20 mill, no where near enough or wide enough to allow a dremel to go through.
In that case, should i drill it out?
SoND
PostPosted: 14:25 - 03 Dec 2005    Post subject: Reply with quote
Might be the only option
Teaman
PostPosted: 14:32 - 03 Dec 2005    Post subject: Reply with quote
take your bike to a bike garage and ask them to do the oil change Smile will cost pennys but at least if they mess up its there fault Smile
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
Bezzer
PostPosted: 16:48 - 03 Dec 2005    Post subject: Reply with quote
Watch the drilling, the heat ends up melting the panel if you're not very careful. I know these things Embarassed
it really is that quick
PostPosted: 17:44 - 03 Dec 2005    Post subject: Reply with quote
buy cheap screw driver that would once of fitted put small amount of super glue on end and carefully super glue to bolt leave to go off and then remove it'll either unwind thread or come straight off so you've lost nothing Thumbs Up
rob
not just any short of winnah... But a Sahf East Winnah
i dont look like your average hortifuckingculturist
The Tot
PostPosted: 18:05 - 03 Dec 2005    Post subject: Reply with quote
Cheers for the sugestions, but the allen bolts were reluctant to move with the superglue method. It's being an arse! I got off the other bolts using the dremel.
Now my main problem is sorting out the sump bolt - see workshop thread. It had managed to chew the bottom of the thread away and consequently can't be torqued up properly.
The last post was made 20 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 61.14 Kb
