Draining a Fuel Tank - How?
Cillit-BANG
PostPosted: 20:48 - 03 Dec 2005    Post subject: Draining a Fuel Tank - How? Reply with quote
I'm about to replace the fuel filter on my Ducati 750ss.
The wonderfull Ducati manual explains everything from pumping up your tyres, to full on engine strip, but no where does it explain how to drain the chuffing fuel tank. Instruction starts with 1) drain fuel tank FFS.
So, is it a case of externally syphoning off the fluid, or is it drained from a fuel-line? If it is the latter, if I disconnect the relevent pipe, I'm assuming there is a diaphram somewhere (no fuel tap) to stop the fuel pissing out for safety reasons. So in which case, how do I by-pass this to get the fuel to actually piss out like I want it too?
I'm sure it's remarkably simple. I'm quite mechanically minded, in fact I've done most of it's 12k service myself, but this bit is driving me potty.
Cheers in advance.
PostPosted: 21:01 - 03 Dec 2005    Post subject: Reply with quote
Does the tap have a 'PRI' position? Use that.
cagiva gezzer
PostPosted: 21:06 - 03 Dec 2005    Post subject: Reply with quote
Suck on the vacuum line with your mouth as no fuel will come out of it. Use the battery overflow tube to extend put on the fuel tap so you can drain it off.
sickpup
Old Timer
PostPosted: 21:08 - 03 Dec 2005    Post subject: Reply with quote
If its fuel injected.
Take the fuel line off the carbs and route into a suitable storage container. Switch the bike on and start the engine and the pump will empty the tank
Carbed.
Raise the tank and the tap is on the under side, its the bit with the dial on it and a pipe coming out.
owdamer
PostPosted: 21:30 - 03 Dec 2005    Post subject: Reply with quote
You need one of these..............
https://uk.geocities.com/[email protected]/files/pumps.jpg
Cillit-BANG
PostPosted: 21:43 - 03 Dec 2005    Post subject: Reply with quote
Cagiva Geezer, no fuel tap on bike
Stinkwheel, no fuel tap on bike.
Sick-pup, Yup it's fuel injected, how can I take off the tube that goes to the carbs?? There are non. If I remove the fuel line, how will the bike tick over to drain the tank? This I might add has been the best suggestion so far Smile
Judging by the replies, I take it there is no simple way of draining a tank?
PostPosted: 21:55 - 03 Dec 2005    Post subject: Reply with quote
You should be able to trigger the fuel pump to run with the engine not running. Might use something like the oil pressure sensor to know the engine is running and so trigger the fuel pump. Or you could just run a line from the battery to the electrical connections to the pump (but be careful doing this, causing sparks while playing with fuel is not a good idea.
Is the pump in the tank or not? Also I presume that there are 2 pipes to / from the tank. One will be a high pressure line from the pump in the tank, one a return pipe from the fuel pressure regulator. Might be that you can just disconnect the return line and drain the tank from there. If you clamp the fuel tank breather hose then the fuel will only run out of the tank very slowly until you get a pipe connected from the tank to a petrol can.
Just a few ideas.
owdamer
PostPosted: 21:56 - 03 Dec 2005    Post subject: Reply with quote
SEE ABOVE.
syphon pumps are about a quid each on ebay. they work great & you dont end up with a mouthful of petrol.
PostPosted: 22:14 - 03 Dec 2005    Post subject: Reply with quote
You can buy automatic siphons where you just put one end in the tank and shake it to start it off.
Remember that if you drain the tank you will still leave the system pressurised so when you undo the filter you will get high pressure fuel peeing out.
Cillit-BANG
PostPosted: 22:54 - 03 Dec 2005    Post subject: Reply with quote
Keith, yup the pump is in the tank.
Under the tank there are 4 connections. 1 pipe marked delivery, 1 pipe marked backflow, 1 marked Drainage, 1 marked bleed. The last 2 are joined via a y-pipe into 1.
So I'm assuming the pipe marked drainage, is indeed for drainage of the tank, but how do I make it drain?!
When the tank is in the upright position, the pipes exit at approximately halfway up. So presumably to drain, the tank will need to lay flat.
PostPosted: 00:13 - 04 Dec 2005    Post subject: Reply with quote
My guess would be that the drain pipe goes onto a small spigot with a knurled knob where it goes onto the tank. If so it is probably the same as used on the old Aprilia AF1. This is a tap. Undo the knurled knob and it allows fuel to flow.
Hopefully that is the situation.
loply
PostPosted: 14:04 - 04 Dec 2005    Post subject: Reply with quote
Drain the tank with a siphon, then run the engine for a minute to empty the fuel rail/injectors/etc?
Yamaha SZR660 Caution to the wind, the throttle pinned!
PostPosted: 14:30 - 04 Dec 2005    Post subject: Reply with quote
Possible, but the pumps need the flow of fuel to stay cool (think that is one reason they are often submerged in the fuel tank).
Cillit-BANG
PostPosted: 19:55 - 04 Dec 2005    Post subject: Reply with quote
No knurled sections, just pipes that join spigots directly from under the tank.
But,
Right. The tank had only 2 or 3 litres left in it anyway, so I remove the filler cap to get access to the fuel pump/filter. I figure its not worth draining anyway. However,
1) Despite the manual clearing showing otherwise, the filter is connected with clips that require new 1's once removed, I have non at home.
2) The tank has developed a load a white crap near the top of tank, presumably it collects where there is usually air space, as the tank is rarely full.
Since it's going in to the workshop to have its belts changed anyway, I'm just going to let them do it Smile They can drain the tank, clean it, and replace the filter whilst they're at it. Shame really because I was in the swing of things.
Good news is that the rest of my first ever service went fine. Bled the clutch and both brakes with no issues, so I'm well chuffed. Although it did require a trip to the dealers for a thermistor which sheared on reassembly, which of course cost £16 for something the size of my thung nail. grrr those gorgous italian bikes Wink
Good weekend tinkering all in all. I feel I have 'bonded'
feef
Energiser Bunny
PostPosted: 13:18 - 05 Dec 2005    Post subject: Reply with quote
is there no tap at all, or just no tap visible?
many bikes have a tap underside of the tank, and is not used by the rider, but is just left open
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
bidman
PostPosted: 15:38 - 05 Dec 2005    Post subject: Reply with quote
Since it's going in to the workshop to have its belts changed anyway, I'm just going to let them do it They can drain the tank, clean it, and replace the filter whilst they're at it. Shame really because I was in the swing of things.
Perhaps it may have been easier just to simply take of the tank tip it upside down until all the petrol comes out? a bit of a hap hazard approach but it works, Thumbs Up Dan
Don't ride it, RAG IT!!
loply
PostPosted: 18:33 - 05 Dec 2005    Post subject: Reply with quote
bidman, its the fuel that has left the tank, and is now in the fuel line, injectors etc that I believe is the problem?
The last post was made 20 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 97.3 Kb
