petrol pissing out!
vfr800
PostPosted: 00:03 - 05 Dec 2005    Post subject: petrol pissing out! Reply with quote
There I was settling down for the night at 9 ish with a can of larger when Cog Head burst through the front door shouting Help, help i've got petrol leaking out all over the place!
If you remember last week his clutch cable went, new one arrives and is promptly fitted, back on the road, yes!
When fitting the new cable he has dislodged the small pipe that comes from the bottom of the carburettor and goes presumably to the nipple a bit higher on the carb, can anyone tell us if thats the correct postmortem or is there something a bit more complicated than that. The bike is a Rieju RS2 50cc race replica (2 smoker)
don't take it easy 'ride it like you stole it'
PostPosted: 00:55 - 05 Dec 2005    Post subject: Reply with quote
If it is coming right from the bottom of the float bowl, it is an overflow pipe.
This is telling you that the float/needle valve assembly isn't functioning properly leading to too high a level of fuel in the float bowl (coming out of the overflow prevents it filling your crankcase with petrol)
Now. Simple things first. Just above the pipe you will see a brass screw, this is a drain screw so make sure it hasn't come loose.
Next give the side of the carb a few sharp raps with a rubber/nylon hammer. The floats sometimes stick and this can free them off (you will be able to tell because the fuel will stop pishing out)..
Failing that it is either a bit of muck in the needle valve, a damaged valve seat, a leaky float or the float height has somehow been mysteriously changed. You will need to take the carb off to check all of these.
pipnet11
PostPosted: 20:40 - 05 Dec 2005    Post subject: Reply with quote
If it only does it sometimes then its almost certainly sticky floats. Sharp tap with something not too solid (soft faced mallet for exapmle) will do it. If it keeps happening then read the rest of stinkwheels post. Carbs are not to difficult to take apart, just make sure everything is very very clean when you put it back together
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
Cog Head
PostPosted: 23:13 - 05 Dec 2005    Post subject: Reply with quote
right then... Evil or Very Mad
i have bodged up my carb for the moment, with a little piece of the outer sheathing of some Cat 5 E cable, and its working...ok ish, just a sod when it kinks, the engine gets all bogged down and dies.
any way...
i fixed that, come home today from school and i see a big box with 50cc.nl on it, its my proformance exhaust Twisted Evil it rocks...
i sorted (bodged) my carb for now any way, and decide to stick my new exhaust on, easy enough...got my old standard exhaust off and it seemed a little heavier than normal, so i tipped it up a bit and looked closely in the exhaust whole and a huge gush pf freekin petrol came gushing towards me, no wounder it wouldnt start... Embarassed
i fitted me exhaust and went for a ride...as you do...and WOW Twisted Evil Twisted Evil it was crazy it flys i loved it, went for a blast arround my area and on the duel carrigeway, not a clue what speed i was doing, spedo said i was going about oil lamp Mph Laughing
i went to meet a m8 and went to go get another m8, and on the way back from his, my freekin throttle cable snapped, NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Sad ...not a happy bunny to say the least...had to push it back to my house which is about a mile or so, which wasn't too bad...so then now i need
*Breakpads Front and back
*Throttle cable
*tubing for my carb
no doubt that this list will continue to grow...
i have come to the conclusen that my bike is cursed Evil or Very Mad
when will the torcheres money spending end ???
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
Joey Bane
PostPosted: 13:53 - 07 Dec 2005    Post subject: Reply with quote
you can find diagrams and such suff at www.dellorto.com
Currently driving: Motorhispania RYZ(yes i'm another ped "boi")
Robby
Dirty Old Man
PostPosted: 17:53 - 07 Dec 2005    Post subject: Reply with quote
This is why its generally recommended that you spend your cash on keeping a vehicle running properly and being properly serviced and maintained first, not spending it on "tuning" parts and the rest of the vehicle breaking.
The last post was made 20 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 50.68 Kb
