Winter Woes - Cold starts a no-no....
krebsy
PostPosted: 09:49 - 06 Dec 2005    Post subject: Winter Woes - Cold starts a no-no.... Reply with quote
I've got a Divvy 600N that, ever since the start of the cold weather, has developed an annoying starting problem. If the bike is in the Garage overnight or outside in the cold then it adamantly refuses to start first thing. The engine fires up and runs very briefly, then it will stop. Hitting the start button again, it will turn over the starter but will not fire up the engine, or maybe "cough" once or twice. If I leave it for a while (10 mins or so) then it will start up most of the time but sometimes the only way to get it running is to drop it into gear, hold the clutch in, give it a good push and then pop the clutch out. The engine won't start on this, but seems to have a better time of starting after that. It's almost as if the engine floods and takes a while to settle.
This morning it fired up on first try and I gave it about 3k revs for 20 seconds or so. Then it cut out as soon as the throttle was closed again (before I could get the choke on).
I've changed the battery over and kept it fully charged. If it has the problem in the morning as I head off to work then it's fine at lunchtime after the 20 mile run. I start the bike up at lunchtime to make sure it is all ok and then it runs fine in the evening for the homeward run.
I don't know what's causing this. Is it simply because it's cold? Today was rather mild though and it had the problem again. Fuel pump? Oil Viscocity? I get the usual Divvy "lurch" if you fire the bike up in neutral when it's cold (clutch plates sticking as the oil is not up to temperature?) and do get resistance initially if the bike is in gear and the clutch is in when push starting. That resistance goes after a few rocks back and forth though as the clutch plates get a good batheing in oil.
The oil is rather dark and is probably in need of a change, I can tell because the right side "overflow" pipe drips oil for a little while after a long run if it's on the side-stand (is this normal?). I will get this done over the next weekend.
Any Ideas? I am reliant on my bike to get to work and will need to do a few 100+ mile runs over winter (not through choice) so need to be able to rely on the Div. It used to start up first go with no issues when I started riding her in August and the problem only surfaced at the start of the cold weather.
Any recommendations or advice would be greatly appreciated.
K.
1280 x 1024.
Redd
PostPosted: 12:15 - 06 Dec 2005    Post subject: Re: Winter Woes - Cold starts a no-no.... Reply with quote
I have the same problem with my 600N but only when it's been seriously sub-zero the night before. From what you said...
Try starting it with the choke fully open. Also check the plugs are clean and free of moisture. After being directed to clean my plugs I've not had any problems with the bike...but it's not been quite so cold lately.
Professional Uberslacker
2006 Kawasaki Z1000 - Black at the front, airbrushed fade to red at the back.
1998 Kawasaki KDX 200 Enduro project bike
Twisted2004
PostPosted: 12:16 - 06 Dec 2005    Post subject: Reply with quote
I've got a xj600s and was having starting and stalling problems when the weather was particulally cold in the mornings.
My bike also leaked oil when on the side stand from the overflow that comes out of the airbox.
I have done a complete service oil, plugs etc. However i also took off the airbox and cleaned it out. Some of the engine breather pipes that do into the airbox had become clogged.
Im not sure whether thats what was causing the starting problems, but im it couldnt have helped.
Give ur bike a service if its time. Try and clean out as much as u can.
Start the bike with the choke out leave it for a while. If its still stalling give it a run by putting it on the centre stand and engaging 1 gear and let it run for a bit.
Previous : DT125 > XJ600S > YZF1000R > Honda CBR1000RR-8 Fireblade (White) - Stolen > Honda CBR125R> Honda CBR1000RR-8 Fireblade (Red)
Current : Ducati Multistrada Pikes Peak (For Sale)
krebsy
PostPosted: 13:02 - 06 Dec 2005    Post subject: Thanks... Reply with quote
Cheers guys, I'll give these suggestions a try and check the plugs and change the oil at the weekend.
K.
1280 x 1024.
Robby
Dirty Old Man
PostPosted: 16:44 - 06 Dec 2005    Post subject: Reply with quote
You should really be firing it up with the choke on, not firing it up then putting the choke on.
Is your idle set high enough? Would expect that to want an idle of about 1200 rpm, but I'd set it more like 1400 if its very cold.
Worth charging the battery too, could be a little tired.
krebsy
PostPosted: 17:01 - 06 Dec 2005    Post subject: . Reply with quote
Battery is regularly charged, Idle speed is at around 1100 to 1200.
Will adjust it up a little (soon as I've read the Haynes Smile ).
1280 x 1024.
Kram
PostPosted: 11:29 - 07 Dec 2005    Post subject: Reply with quote
i get the same problem on my fzr. it starts at the push of a button with 1/2 inch of ice sat ontop,. but then stops and takes a good 5 minutes turning it over with the starter to go anywhere, the choke doesn't help either.
but i'm stripping mine and cleaning it hopefully next week (or friday) so i will see if i can find the solution, as it might help yoiu guys out also.
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
krebsy
PostPosted: 17:39 - 07 Dec 2005    Post subject: gave some suggestions a try. Reply with quote
I tried a few of the things out and slapping on full choke, knocking it into first, pulling in the clutch and then hitting the starter worked. I fired up the bike this morning and as soon as it had caught I let the clutch out and left it warming up in first gear on the centre stand. Was fine at lunch, now I'm off home so in a few mins and I'll know if it's going to get me home. It was much colder as well this morning, so it seems I have learned "the knack" from you all... Smile..
Ta,
K.
1280 x 1024.
shammon
PostPosted: 23:00 - 07 Dec 2005    Post subject: Reply with quote
My xj600 pre Divy takes ages to warm up with new plugs def helped starting. also i had to adjust the idle speed up a slight bit.
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
DanceLikeAMon...
PostPosted: 09:31 - 08 Dec 2005    Post subject: Reply with quote
I read about someone else on here saying they did the same thing. How do you keep it in first gear without the clutch being in? My bike would just stall, and I thought all bikes would (or am I missing out on some kind of bike trickery?)
krebsy
PostPosted: 21:41 - 09 Dec 2005    Post subject: Reply with quote
Get it up onto the centre stand and let the clutch out as soon as the engine has caught.
K.
1280 x 1024.
DanceLikeAMon...
PostPosted: 22:08 - 09 Dec 2005    Post subject: Reply with quote
But my bike would stall if I did that unless I was revving it. Confused
gimpy limp
PostPosted: 10:10 - 15 Dec 2005    Post subject: Re: Winter Woes - Cold starts a no-no.... Reply with quote
[quote="Redd"]I have the same problem with my 600N but only when it's been seriously sub-zero the night before. From what you said...
not got your rebel anymore mate then? I quite like that rebel of yours wouldn't mind one like that when you decide to get rid
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - sam.barwick@ntlworld.com
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
Redd
PostPosted: 11:03 - 15 Dec 2005    Post subject: Re: Winter Woes - Cold starts a no-no.... Reply with quote
Really ? I've got a few jobs to do on it now that I don't have to ride it to work every day (replace exhaust gaskets & collets, check the wiring on the indicators) but I could be persuaded to sell it. It's not exactly in mint condition but would be a great road-going project bike. It even started first time last weekend after been sitting for a month.
sorry for the thread hijacking
gimpy limp
PostPosted: 14:26 - 15 Dec 2005    Post subject: Reply with quote
cool, I'll have to see what money I can muster together sometime after christmas i've been wanting a 125 project bike for a while.
kawakid
PostPosted: 22:25 - 17 Dec 2005    Post subject: Reply with quote
mine's being doing something simmilar, other week was taking 5 or 6 goes to start. I have since been removing battery from bike and keeping it in airing cupboard.
Also when starting, choke fully out before starting, then keep turning, even after its got fired, just get revs going.
I've a twin and a 4.
The last post was made 20 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 92.03 Kb
