CG125 air filter - inane question
mchaggis
PostPosted: 17:00 - 07 Dec 2005    Post subject: CG125 air filter - inane question Reply with quote
Having not looked at it since the machine was bought, I took it to pieces today. The foam element was mostly missing, lying in a pile behind the gauze filter. Oddly, the sparkplug was showing it running rather rich if anything. Confused
Anyway, I know where one of the gauze filters goes, and it's obvious where the foam filter goes, so where does the second filter go? It was floating about between the two, not slotted into anything. Surely the foam won't be pulled to shreds in quite the same way if there is a gauze filter immediately before it? I can't really believe it is supposed to go where I found it; the slot for the gauze filter isn't big enough for two.
https://www.bikechatforums.com/files/cg125_air_filter.jpg
I must not be a troll...
Mmmm, Guinness
DynamiteBoy
PostPosted: 20:11 - 18 Dec 2005    Post subject: Reply with quote
On my cg the second gauze filter sits directly in front of the foam air filter, both gauze filters should be placed on the carb side of the foam. You should be able to position the loose gauze filter in the slot with your foam air filter.
Hope this helps...
The last post was made 20 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 31.93 Kb
