Rear paddock stands
Groove
PostPosted: 00:02 - 09 Dec 2005    Post subject: Rear paddock stands Reply with quote
How do you put your bike on it? Embarassed
Hard? Easy?
Thinking about one as an xmas prezzie Smile
Klause
PostPosted: 00:09 - 09 Dec 2005    Post subject: Reply with quote
Helps to have another person to hold the bike straight. Do able on your own.
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
pjones_po
PostPosted: 00:10 - 09 Dec 2005    Post subject: Reply with quote
I did it on my own once.....fook that for a game of soldiers, my nads arent big enough for me to attempt it a second time! lol
Vin
PostPosted: 00:11 - 09 Dec 2005    Post subject: Reply with quote
Dead easy if you have a 1988 TZR250
I would imagine its a nightmare if you have a brand new Fireblade Laughing
Groove
Confused
So its pretty hard on you own, but still, how do you do it?
Vin
PostPosted: 00:13 - 09 Dec 2005    Post subject: Reply with quote
Groovearmada wrote:
Confused
I'd rather not say Embarassed
Groove
PostPosted: 00:15 - 09 Dec 2005    Post subject: Reply with quote
It just slid under the swingarm and lift up? Shocked
woo
PostPosted: 00:16 - 09 Dec 2005    Post subject: Reply with quote
i do it on my own, just silde the holders underneath the bobins.
Elen sila lummen omentielvo!
loply
PostPosted: 00:20 - 09 Dec 2005    Post subject: Reply with quote
You slide the stand under the swingarm, then with one hand you stand the bike upright, and push down on the stand so it rotates the bike off the ground.
Bit tricky on your own but once youve done it a few times its quite routine
Yamaha SZR660 Caution to the wind, the throttle pinned!
Groove
PostPosted: 00:25 - 09 Dec 2005    Post subject: Reply with quote
Are they stable enough in strongish winds?
Seen some cheapish ones on Ebay Wink
EuropeanNC30R...
Gay Hairdresser
PostPosted: 00:27 - 09 Dec 2005    Post subject: Reply with quote
The single-sided ones are easy as they're slotted inside the rear wheels hub - very stable.
Mr.Everready
PostPosted: 01:00 - 09 Dec 2005    Post subject: Reply with quote
I shit myself nearly evey time I do it. Laughing
It's easy when you've got the knack. Have someone with you for the first few times you try it just incase the bike loses balance.
mchaggis
PostPosted: 12:42 - 09 Dec 2005    Post subject: Reply with quote
I thought sod that for a game of soldiers, so bought myself a trolley jack and acquired a pile of bricks. Does the trick for both ends. Thumbs Up
I must not be a troll...
Mmmm, Guinness
pj25
PostPosted: 13:12 - 09 Dec 2005    Post subject: Reply with quote
I put my k3thou on paddock stand regular by myself. Make sure you get the bobbin's and hook type(if you can fit bobbin's on your bike)
Help's if you put the pillion seat on then you can grab the bike by it stand the bike up level(stand on the right hand side leave the sidestand down) OH yeah leave it in gear to. then line the hooks up and push down on the stand. Thumbs Up
wasnt me, honest!!!!!
fuzz
PostPosted: 13:23 - 09 Dec 2005    Post subject: Reply with quote
On lighter bikes, ie my NSR, I put a block of wood under the sidestand to level the bike, then steady it by the grabrail while lifting it with the paddock stand.
I attempted the same with the SV, but it bent the paddock stand as the weight wasn't distributed properly.
0ni
PostPosted: 13:56 - 09 Dec 2005    Post subject: Reply with quote
Piece of piss to be perfectly honest with you.
On my Srad, which is neither the smallest or lightest bike around you simply leave the bike on its side stand and place the left hand side of the stand under the left side of the swingarm. Simply apply pressure and the bike will stand itself up making contact with the right hand side of the swingarm. Now that the bike is upright just apply pressure and it will rise into the air.
The hairy part is getting it down the first time, just have a little bit of faith that it will rest on the stand and you'll be fine.
oni
Its a lovely day, just wait until some bastard spoils it.
owdamer
PostPosted: 19:53 - 09 Dec 2005    Post subject: Reply with quote
I stick my yzf750 on the paddock stand on my own, its a piece of piss & thats with a 195kg bike.
The bike has bobbins on the swing arm, & the stand has adaptors that hang down.
I only use the bobbins if i'm taking the back wheel out. For general day to day use I run a 10mm bar thru the rear axle, supported at each end by the stand. (see pic).
https://uk.geocities.com/[email protected]/files/stand.jpg
riichy
PostPosted: 20:12 - 09 Dec 2005    Post subject: Reply with quote
i get my mum to help me put it on the stand.... Mr. Green
i have at the min one that gos on the swing arm, but these wreck the paint so dont get one Exclamation ....
for x-mas am getting some bobbins and a stand to fit them much easer Mr. Green Thumbs Up
.......... PLOD ............ zx636 2004
The last post was made 20 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 98.59 Kb
