 Posted: 17:13 - 11 Dec 2005 Post subject: Warning light oddity KLE500 *fixed* |
On my KLE500 which is broadly similar to all the other kawasaki 500 twins (GPZ/EX/EN).
When you switch the ignition on, the neutral light, oil pressure warning light and temperature warning light all come on as is normal.
When you start the engine, the oil and temperature light should go out straight away. Well they don't. Both stay on for a bit then gradually start to flicker (together) then go out and stay out.
This worried me a bit but looking at the sight glass, you can see the oil go down as you start the bike. There is plenty oil in and I did an oil and filter change last weekend. It didn't do this light thing when I took it out after the oil change.
It definately isn't overheating because the engine was cold at the time.
I worried that it could be a charging warning but I have just got back from a 400 mile run with the lights on and it is still fine. This would also tend to rule out an oil pressure problem as it hasn't blown up.
So, why? I have come up with two possabilities so far.
1) An airlock in the oil filter, but I would have thought this would cause the oil light only to come on.
2) My 'most likely' guess. A sticky/duff charging relay. Although finding where it is located may prove a challenge.
Any other ideas? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Guest |
 Guest Brolly Dolly
| tonyyzf |
 tonyyzf Brolly Dolly
| tonyyzf |
 Posted: 23:20 - 11 Dec 2005 Post subject: |
| tonyyzf wrote: | Am I right in presuming these lights would also come on if it stopped charging? |
I think you hit the nail on the head. I am presuming, and will be doing so until I get a look at a wiring diagram.
I am pretty sure it must be some form of 'charging warning' light when both come on at once. Just the intermittant nature that puzzles me, as well as the fact that it 'flickers' for a bit before going out. You would have thought it was either charging, or not charging. I can't see how it would not charge for the first 10-15 seconds after starting then charge for the next three hours.
Incidentally, once it's running and warmed up, if you switch the engine off then fire it straight back up again, they go out straight away. If you leave it off for say 10 seconds then fire it up, the lights stay on for a bit. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| tonyyzf |
 Posted: 09:57 - 12 Dec 2005 Post subject: |
| Quote: | Incidentally, once it's running and warmed up, if you switch the engine off then fire it straight back up again, they go out straight away. If you leave it off for say 10 seconds then fire it up, the lights stay on for a bit. |
Ok, the major components in the charging system will be Alternator (AC) rectifier to change from AC to DC, voltage regulator and battery. Have you tried connecting a volt meter to the battery and starting the bike, does the voltage at the battery increase at the same time as the lights go out? If so then its confirmed its a charging issue. The way you describe it is like there is something in the system holding the charge a bit once the lights go out, like a capacitor does in a tv or amp, then its draining shortly after the bike stops, so it must be one of the electrical components, but why the delay when starting from cold? That leaves you to find where the fault is, the rectifier? regulator? is there anything else in that system, a balast resistor maybe? |
 Posted: 11:50 - 12 Dec 2005 Post subject: |
It does not go out any faster with the lights on or off, I haven't put a meter on it but the headlamp does get brighter when you rev it up, even when the lights are on which suggests to me that it is charging.
I keep coming back to a sticky relay. It is probably in the fuse box. I think I will try smacking it with my favourite nylon hammer. If the lights go out when I do this, I have found my problem.
I really detest intermittant electrical faults. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| rg 250 freak |
 rg 250 freak Derestricted Danger
 Posted: 13:36 - 13 Dec 2005 Post subject: |
Some charging systems will not kick into life until certain revs have been exceeded once (we had a car that did not charge the battery at all until the first time it was revved to about 3300rpm). Do the lights go out if you blip the throttle.
Also, on our first GPZ we found out that there is an O ring or 2 between the sump plate and the oil ways in the engine. If these are damaged / missing then you will land up with low oil pressure through much of the engine, but only enough to light the oil light at very low revs (scratch one engine).
| MikeH |
 MikeH Brolly Dolly
 Posted: 20:43 - 16 Dec 2005 Post subject: |
It's got to be duff electrical connection somewhere, it's not going to be oil pressure or charging as both lights are flickering at the same time even though they are not directly related.
K.I.S.S. ........check the simple stuff 1st loom connectors, earths etc......put money on it it'll be something stupid. Could be chaffed cables in the instrument pod which are getting damp and it's picking up a signal off the rev counter
I've got a link to a full workshop manual if you need it, I posted it here https://www.bikechatforums.com/viewtopic.php?p=788133#788133
Cheers
Mike  ____________________ Busa Junkie |
| tonyyzf |
| MikeH |
 MikeH Brolly Dolly
 Posted: 11:07 - 17 Dec 2005 Post subject: |
Cheers for that guys. I'll be having a poke about this afternoon as well as attempting to fit a bigger fuel tank off a KLR650 Tengi.
I'll let you know how I get on.  ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| tonyyzf |
 Posted: 15:01 - 17 Dec 2005 Post subject: |
Ok, as ever nothing you would expect. It wasn't an electrical problem, it was a mechanical one and I fixed it with a hammer.
I started by removing the bodywork to make life simpler. I have got into the habit of checking an electrical fault is still there after removing each plastic, then you know where to look for a trapped wire if that is the fault.
Well, I removed the belly pan and the fault went away. Now that is odd there are no wires anywhere near it. Warrants a closer look.
Turns out the belly pan was touching the new exhaust system slightly, but only when fully tightened up. This was pressing the header pipe very close to the end of the oil pressure switch. When you first fire up the bike there is a fair bit of vibration, enough to press the header against the end of the switch. As the oil pressure builds, it counteracts this small pressure on the switch and the lights go out. The flickering was the header pipe vibrating.
The diode is fine. If oil pressure is low, both lights come on, if it is temperature only, the temperature light comes on by itself.
Gave the belly pan a few clouts with a hammer and shoogled the header pipe about a bit and job's a good un.
If anyone is planning on fitting an aftermarket exhaust, be carefull how you set it up, there is only a very small area where the pipe is away from both the belly pan and the switch. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Guest |
 Guest Brolly Dolly
 Posted: 16:29 - 17 Dec 2005 Post subject: |
Good one.
Now put it back to how it was and see if a dealer can find it  |
| MikeH |
 MikeH Brolly Dolly
 Posted: 17:17 - 17 Dec 2005 Post subject: |
| stinkwheel wrote: | Ok, as ever nothing you would expect. It wasn't an electrical problem, it was a mechanical one and I fixed it with a hammer.
If anyone is planning on fitting an aftermarket exhaust, be carefull how you set it up, there is only a very small area where the pipe is away from both the belly pan and the switch. |
Fair play, that could've been a right twat to find ____________________ Busa Junkie |
The last post was made 20 years, 101 days ago. Instead of replying here, would creating a new thread be more useful? |
