Sticking clutch... or something more sinister?
Method
PostPosted: 23:48 - 12 Dec 2005    Post subject: Sticking clutch... or something more sinister? Reply with quote
My bike is becoming a bit of a problem to push backwards...
This happens when the engine is running and when its not, and also when im plodding along in traffic early in the morning... when the engine is still a bit cold... the bike will be realy kind of sticky if you know what i mean, and it will seem to drag a lot and slump to a almost stop very quickly. It will also sound like im riding with the rear brake on, with the bike sounding very throaty and the revs building without any speed gain...
Now i would say that the rear/front brakes are binding... but the problem when riding seems to go when i rev it up a lot and maybe free the clutch up a bit?
But then even with a warm engine, when i try and push it back, engine off or not, it still seems to be hard to push, if not impossible, in gear with the clutch in... and sometimes even in neutral?
Im realy confused as to what to check tomorow in the light.. Confused
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
mchaggis
PostPosted: 00:02 - 13 Dec 2005    Post subject: Reply with quote
I had a problem just like that with a drum brake rear, after I forgot to adjust the brake when I moved the wheel back to get the chain tension correct. I suppose the rear disc could be siezed on?
I must not be a troll...
Mmmm, Guinness
R4nger
PostPosted: 00:08 - 13 Dec 2005    Post subject: Reply with quote
Put the GS on the centre stand and try and push the rear and front tyres by hand. They should move freely. If not then it is probably something binding like the brakes.
If the wheel moves freely, try it in neutral and in gear etc. If it is in neutral then the clutch plates are not the reason since they will be dis-engaged from the gear box.
It's just of process of elimination.
The last post was made 20 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 37.59 Kb
