| Aikman666 |
 Aikman666 World Chat Champion
 Posted: 23:13 - 12 Dec 2005 Post subject: Cheapo Bike Cam |
Roiiight, im thinking of putting together a cheap bike cam for a laugh. Basicly ive got an old digital camera that no one uses anymore. Ive already got the rechargables and im planning on buying a bigger SD card for it (plenty of action ). BUT ive got a few queries:
According to the PC, it records at 7fps: is this fast enough?
Will the cam be able to cope with vibrations? (dont care if it breaks)
Where is the best place to mount it?
How is the best method of mounting it? ____________________ Will work for petrol
My Design Blog |
| T1z3R |
 T1z3R World Chat Champion
| Aikman666 |
 Posted: 23:21 - 12 Dec 2005 Post subject: |
Its a 'Mercury Deluxe Classic cam' although ive seen the exact design used by numerous companies. The cam is hard as nails, and i used it to shoot a skating video not long back and it done an ok (seeable) job. According to windows it records at 320x240 pixels too
Pictures of the wondercam attatched (its not as big as it looks). ____________________ Will work for petrol
My Design Blog |
| mr.z |
 mr.z World Chat Champion
 Posted: 23:23 - 12 Dec 2005 Post subject: |
| Quote: | According to the PC, it records at 7fps: is this fast enough? |
Depends, its going to be quite poor more than likely... try it in a car, stick it out the window and see how that looks..
| Quote: | Will the cam be able to cope with vibrations? (dont care if it breaks) |
Depends on how carefully you mount and where, on a tank bag (you'll have to be inventive) vibrations wont be too bad, but it will be tricky to aim straight
RAM make mounting brackets which are dampened and i've used myself for cameras and it worked quite well
There are sucker tank cam holders, but they are too expensive for what they are, ram mount is better by far...
| Quote: | Where is the best place to mount it? |
See above The advantage to bar mounting is it pointing where you are pointing.. ideally it should be mounted as low as possible, lower the angle the faster+better it looks
| Quote: | How is the best method of mounting it? |
The ram mounting bracket is cheap, dampens the vibes and is fully adjustable for wherever you want it, strong as a very strong thing too..
However, if you really dont care, you can mount the camera with a 6/8mm (not sure which) bolt into the base of the camera, if its made of plastic then its iffy, either case secure with cableties.
EDIT - Mounting it direct to the frame e.t.c. WILL f@ck it in short order ____________________ >RidingSkills<->Tech Tips<->MyBikes<
| T1z3R |
| Aikman666 |
 Posted: 23:27 - 12 Dec 2005 Post subject: |
What i was thinking was that there is a spare tapped hole where my ( i think its left hand side) mirror should be, i could get my dad( or i could do it if there wasnt so much shit in the garage) to whip up an adapter bolt, one side into the mirror mount, other side into the tripod mount on the camera, and fasten some cable ties round.
*Edit: forgot to mention, will be fitted to the RX50 ____________________ Will work for petrol
My Design Blog |
| mr.z |
 Posted: 23:28 - 12 Dec 2005 Post subject: |
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
 Posted: 23:30 - 12 Dec 2005 Post subject: |
7fps , my camera records at 15fps and I wouldn't consider it with that.  |
| T1z3R |
| Aikman666 |
 Posted: 23:39 - 12 Dec 2005 Post subject: |
I took this little tester video last night when i first gave birth to the idea. The video seems a bit choppy, but thats because the acctual visulisations are choppy. The only grudge i would have is that as soon as light levels drop, the quality goes to shit. ____________________ Will work for petrol
My Design Blog |
| mr.z |
 Posted: 23:45 - 12 Dec 2005 Post subject: |
This is off a DV2000, cheapo camera 15fps (as in the pic)
Lightlevel changes make these go a bit mad, can take 5/6 seconds to sort itself out (which is quite a long time) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Aikman666 |
 Posted: 23:52 - 12 Dec 2005 Post subject: |
Seems not bad at all, still good at high speeds? I will try shooting the camera out the window of a car, if it looks ok i'll drag the bike out the garage tommorow, and have a look at my options. If the camera sucks, i'll resort to cash converters Sometimes they have good, reasonably priced crap in! Thanks for all the help guys, i'll repost tommorow with what happens! ____________________ Will work for petrol
My Design Blog |
| -Savage- |
 -Savage- World Chat Champion
| T1z3R |
 Posted: 00:23 - 13 Dec 2005 Post subject: |
winrar mate.
www.rarlab.com ____________________ duck my sick! |
| Rookie |
 Rookie World Chat Champion
The last post was made 20 years, 205 days ago. Instead of replying here, would creating a new thread be more useful? |
