| jaydr |
 jaydr Borekit Bruiser
 Posted: 08:22 - 23 Nov 2005 Post subject: misfiring problems |
hey all!
ive got a chinese copy of a gs 125 although its a copy of a suzuki apparently it has a copy of the cg125 engine!?! Anyhoo recently it started to just be a bit hesitent at times mostly at full throttle and over the last week it has got progressively worse and now it struggles to do 30 mph and backfires like mad no matter how gently you throttle it. I have been told to check the points on it but i have no idea where they are and also i think it could be a timing problem but again i have no idea how to adjust that?
please help as its driving me mad!!!!
cheers
jay ____________________ i smile because i have no idea whats going on! |
| the grim reaper |
 the grim reaper World Chat Champion
| bidman |
 bidman Crazy Courier
| jaydr |
| bidman |
 Posted: 19:46 - 23 Nov 2005 Post subject: |
yeah your engine is a cg 125 replica, so all the parts are in the same places etc...
First check the spark plug and make sure it isn't fouled or oily and has the correct gap, also change the oil and ride it to see if this has any effect on the problem.
If not you need to check the points gap. The points are situated under the flywheel and as such are a bugger to get right. My advice is to take it in to a bike mechanic and get them replaced and checked. While your there get them to check the advance/retard mechanism. This is fixed inside the flywheel and are known for going wrong. Theres just springs and bob weights which fly out under centrifugal force and advance the timing. The springs get slack and advance the timing causing farting and popping and flat spots etc... Also check that the exhaust pipe has a sealing ring in the exhaust port. This can cause a backfire if it is missing. Now pull apart all the iginition bullet connectors and clean them. Do the same for the battery leads. When you have done that carefully nip up all the female bullets so you have a snug fit. Then make sure the spark plug is in firmly because if it is loose it will cause loss of compression. Let me know how it goes or if you get stuck , Dan ____________________ Don't ride it, RAG IT!! |
| jaydr |
 Posted: 08:38 - 24 Nov 2005 Post subject: |
cheers dan!
have you got any idea what the plug gap should be i just changed it last weekend but i just stuck it straight in without looking at the other first! also i got a new ht cap and chucked a bit of redex in the tank as i had let it run nearly dry i thought maybe the bike had sucked some crap into the carb? im gonna have a look at work tonight give it a good clean. ____________________ i smile because i have no idea whats going on! |
| the grim reaper |
 Posted: 14:17 - 24 Nov 2005 Post subject: |
OK, scratch my comment, I didn't twig that it was a four stroke
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
| bidman |
 Posted: 15:32 - 24 Nov 2005 Post subject: |
well i'm presuming it'l use the same plug as the cg which is a DR8ES-L and a gap around 0.7 and 0.8 should be fine a new plug comes with the correct gap for the cg so maybe just get hold of a new 1  ____________________ Don't ride it, RAG IT!! |
| jaydr |
| bidman |
 Posted: 18:32 - 24 Nov 2005 Post subject: |
Hi, the gap will be the same anywhere between 0.7 and 0.8 will be fine  ____________________ Don't ride it, RAG IT!! |
| jaydr |
 Posted: 18:42 - 24 Nov 2005 Post subject: |
thanks bidman
is that gap you quoted for the spark plug or the points? ____________________ i smile because i have no idea whats going on! |
| bidman |
 Posted: 18:48 - 24 Nov 2005 Post subject: |
Hi, thats the spark plug gap the points gap is 0.35mm  ____________________ Don't ride it, RAG IT!! |
| jaydr |
| bidman |
 Posted: 19:15 - 24 Nov 2005 Post subject: |
Yes i think the points are inside the flywheel, well they were on a similiar replica cg125 engine i had, removing the flywheel is an easy job as long as you have the right tool for it if not just take ti to a garage for them to take off for you  ____________________ Don't ride it, RAG IT!! |
| jaydr |
 Posted: 19:25 - 24 Nov 2005 Post subject: |
thanks m8y!
will have a look when i get to work! ____________________ i smile because i have no idea whats going on! |
| jaydr |
 Posted: 08:21 - 01 Dec 2005 Post subject: |
just a quick update on the problem. I tried to take the cover off the flywheel but to no avail, it seemed solid even after id removed all the bolts, Anyway there is a large screw that you can remove and you can see the flywheel and also iam greeted with loads of oil being flung at me! i dont know whether this is how it should be but i thought the flywheel should be dry? also the wierd thing is if i take that screw out for a minute and run the bike it runs perfectly for about 20 miles then does it again!?! i cant get any parts for this bike ive been told that the parts from a cg engine will not fit this bike at all so i was thinking maybe i could get a cg engine for it if its a straight swapout? ____________________ i smile because i have no idea whats going on! |
| bidman |
| jaydr |
| bidman |
| jaydr |
| jaydr |
 Posted: 14:42 - 13 Dec 2005 Post subject: |
took carb off and cleaned it all out, fuel was clean and not much muck in the carb, ive put it all back together now and the problem is no better so now im really baffled can anyone tell me how to get the flywheel off please as ive got no idea how! it has 3 allen key bolts and a large centre nut but there is nowhere for me to jam the engine to undo it as the flywheel is solid. ____________________ i smile because i have no idea whats going on! |
| Robby |
 Robby Dirty Old Man
| jaydr |
| jaydr |
| gimpy limp |
 gimpy limp Nearly there...
 Posted: 11:02 - 15 Dec 2005 Post subject: |
you still having no luck mate? make a list of what you've checked to date and chuck it up here it might be easier to follow and work out that way. It's frustrating problems like this but these sort of things you learn loads from I find, better than any mechanics course imo - you'll know where to go first if it happens again on any future bikes. ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - sam.barwick@ntlworld.com
https://pre-auto.com/cx500/rat_and_survival_gallery_2006 |
The last post was made 20 years, 120 days ago. Instead of replying here, would creating a new thread be more useful? |
