Cornering like a pro
Whosthedaddy
PostPosted: 22:10 - 13 Dec 2005    Post subject: Cornering like a pro Reply with quote
I have recently passed my bike bike test and bought a Kawasaki ZXR750 as my first bike.
I am having a real problem turning the damn bike at any speeds! I learnt on a ER5 with no problems, is it confidence to lean the bike or a problem with a sports bike set up?
Any suggestions on how to start cornering like a pro?
T1z3R
PostPosted: 22:12 - 13 Dec 2005    Post subject: Reply with quote
welcome to the neighbourhood Smile
i'm certainly no pro but would guess its to do with confidence rather than your bike.
i know for sure that i'd wait till the conditions were better before i worried about that TBH Smile
good luck Thumbs Up
duck my sick!
Quote Me Happy
Try searching for "counter steering" Thumbs Up
PostPosted: 22:12 - 13 Dec 2005    Post subject: Re: Cornering like a pro Reply with quote
It's probably confidence and getting used to a new bike.
They are pretty differently styled bikes, so while the sports bike should be able to go round corners faster, the difference in feel may make it feel 'wrong' initially.
As with everything in riding bikes fast, get quicker slowly - just try increasing your speed only a little bit at a time.
Given time, I'm sure you'll get used to it.
Whosthedaddy
PostPosted: 22:32 - 13 Dec 2005    Post subject: Reply with quote
Thanks for the replies, cannot wait for a nice "sunny" winters day to go for a ride
Barry_M2
PostPosted: 22:36 - 13 Dec 2005    Post subject: Reply with quote
Good choice! Wink
What does it feel like when you corner, do it feel like a strugle to get it leant over?
I had this problem with mine when I first too it out. Went straight to a garage and checked the tyre pressures, both were well out. 22psi front and 28 rear, when it should be 36/42. Check your pressure! Thumbs Up
The Old Geeza
Back in my day...
PostPosted: 22:46 - 13 Dec 2005    Post subject: Reply with quote
Agreed Thumbs Up
If it wasn't for people like Joe, map, flip, stinkwheel, white noise and many others too numerous to mention (my apologies for not including all of you in the initial list, but you are acknowleged all the same), I would never have realised what counter-steering was.
Thanks to everyone Thumbs Up
Horse Power was safer when the Horses had it!
mchaggis
PostPosted: 22:50 - 13 Dec 2005    Post subject: Reply with quote
Find a nicely surfaced twisty road without much traffic and good visibility through the corners*, and ride it again and again, pushing harder each time, eventually you will feel when the tyres are both sliding towards the outside of the corner, then you can't go any faster without them losing grip completely. Smile
*A rare thing I know, but they do exist, old little roads running parallel to major new routes are good, as are a lot of the roads running around all over the Peak District and rural Scotland.
I'm not guilty if anyone lowsides trying to explore the limits of traction in dodgy conditions. Whistle
I must not be a troll...
Mmmm, Guinness
moog
PostPosted: 23:06 - 13 Dec 2005    Post subject: Reply with quote
I think it's 90% confidence and 10% variables (tyre pressure, tyre choice, tread, and factors that affect grip such as conditions, speed, surface etc). In your position I'd be tempted to put the miles in and actually get used to the bike under normal riding first before starting to explore it's limits. Learn to walk before you run is a much used cliche I know, but I feel it's apt here. Whatever you choose to do though, have fun and stay safe.
"A process which led from the amoeba to man appeared to the philosophers to be obviously a progress...though whether the amoeba would agree with this opinion is not known."
"I've made an odd discovery. Every time I talk to a savant I feel quite sure that happiness is no longer a possibility. Yet when I talk with my gardener, I'm convinced of the opposite."
craigs23
Mr Muscle
PostPosted: 09:12 - 14 Dec 2005    Post subject: Reply with quote
ZXRs aren't the lightest bikes to turn either - a friend of mine gets a good workout when hussling down the backroads trying to keep up with our 400s.
Annabella
Like a person, only smaller
PostPosted: 10:00 - 14 Dec 2005    Post subject: Reply with quote
Move around a bit more...
Until I started taking the mickey out of Shaun and his tendancy to hang off the boke when going around even the most tame of radius corners I would never have felt as smooth around corners.
Avast! Pirates ahoy!
I did Cadwell! Very Happy
Teaman
PostPosted: 20:47 - 14 Dec 2005    Post subject: Reply with quote
take the steering lock off,,
well everyone else has already mentioned the counter steer bit
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
loply
PostPosted: 21:03 - 14 Dec 2005    Post subject: Reply with quote
Did you have somebody more experienced test ride the bike before you bought it?
Just in case there is a problem with the tires being squared off or the forks being bent or somesuch.
Might just be in your mind though.
Yamaha SZR660 Caution to the wind, the throttle pinned!
jonnay
PostPosted: 21:44 - 14 Dec 2005    Post subject: Reply with quote
I got my knee down for the first time, the other day Very Happy Had a sunny day so I just decided to go out and try it. Well pleased about that.
I'd say do what I did, lap round and round a BIG roundabout (not in rush-hour though, I did it at about 1pm when it was quiet), and just hang off it and feel it go. I wasn't actually expecing to knee down, but I heard that hanging off makes it more steady and less likely to slip, so give that a try Smile
If nothing else, this should give you a bit of confidence in your machine - it has to me.
Watch out if its a 2 lane roundabout though, as I found out - there's a BIG dip between the lanes, which my front wheel kept finding itself in. Scary as feck when that happened the first time Shocked
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
riichy
PostPosted: 23:16 - 14 Dec 2005    Post subject: Reply with quote
knee down in winter...respect to the man Shocked Thumbs Up
.......... PLOD ............ zx636 2004
jonnay
PostPosted: 23:45 - 14 Dec 2005    Post subject: Reply with quote
Respect to the council for keeping one roundy clear Laughing Thumbs Up
Seriously though, it wasn't slipping at all, road surface is really good on this one particular roundabout. Just gotta watch out, because two of the run-offs from the main A road to West Cornwall run onto it.
It also goes through a tunnel, which is a bonus (tunnels are fun Smile )
Jon
cliff
Doctor Sicknote
PostPosted: 23:46 - 14 Dec 2005    Post subject: Reply with quote
Ive had kneedown on a ped in the snow. And my zxr a few times in the pissing rain. Its all about confidence and hanging off. Smile
Sweet reggae music.
riichy
PostPosted: 23:51 - 14 Dec 2005    Post subject: Reply with quote
KD on a ped *riichy gets down on his knees* am not worthy..... Thumbs Up
Barry_M2
PostPosted: 11:00 - 15 Dec 2005    Post subject: Reply with quote
But what you failed to also mention is that you only managed it as you were in the process of falling off! Laughing
distortion
PostPosted: 11:10 - 15 Dec 2005    Post subject: Reply with quote
Trackdays should help you - not exactly the time of year for it. But when the weather picks up I reckon there well worth doing Thumbs Up
Groove
PostPosted: 11:27 - 15 Dec 2005    Post subject: Reply with quote
I had my knee down on my ZXR, pitty i had left the bike and was sliding along the ground at the time.... Laughing
Whosthedaddy
PostPosted: 20:48 - 15 Dec 2005    Post subject: Reply with quote
Cheers guys and gals for the suggestions.
Unfortunately after attempting to ride a little more aggressively and flick the bike into a corner, the damn thing broke down. It ended up in a lay-by. It took me an hour to walk back home to get my car! Just hope no bastard gypos have nicked it!
Groove
PostPosted: 20:50 - 15 Dec 2005    Post subject: Reply with quote
Shocked
How did it break down? Sad
Whosthedaddy
PostPosted: 20:57 - 15 Dec 2005    Post subject: Reply with quote
After a couple of horrendous backfires in the fast lane at 70mph, all engine and electrical power went!
Gazdaman
I did a trackday!!!
PostPosted: 21:05 - 15 Dec 2005    Post subject: Reply with quote
Hope you sort the bike out ok.
But you just need to get used to your new bike. They're very different to an ER-5, the more sport orientated bike will need a different approach.
I'm still finding it very weird on my Bandit, whereas I could hustle my old XJ600 around as quick as any of the guys I ride with.
Get quicker slowly, and it may help to wait for some dryer days, I really hate winter and the slime that encompanies it.
Gaz
The last post was made 20 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 132.74 Kb
