Dragging clutch?
quik_d
PostPosted: 22:17 - 13 Dec 2005    Post subject: Dragging clutch? Reply with quote
Hi there i'm hoping someone might be able to shed some light, my bike in missing gears, only every now and then but getting more frequesnt, and 2nd pops back into neutral sometimes. Oh and if i accelerate from a standstill quite rapidly i dont actually get anywhere fast, its like i've still got the clutch in, and then suddenly it starts pulling better. The chain is too slack and i will be sorting that at the weekend, is that the liekly cause, else i was thinking:
Clutch dragging
Gear plates getting on now, maybe need replacing?
Also do you actually need the "special" home chain adjuster tool for the honda bros or can the chain be adjusted with conventional tools?
Ta,
Dean
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
RSheale
PostPosted: 22:55 - 13 Dec 2005    Post subject: Reply with quote
i dont see why you can't use regular tools?
if adjusting your chain doesn't sort it then it probably is your clutch plates are worn out
how long have you been using them for?
PostPosted: 23:00 - 13 Dec 2005    Post subject: Re: Dragging clutch? Reply with quote
Hello,
You can adjust the chain with a hammer and a screwdriver, but you'll mash the chain adjuster.
Just go and buy a C spanner. They are dead cheap anyway.
its likely to be the chain, and even if it isn't it still needs adjusting. Karma
quik_d
PostPosted: 23:02 - 13 Dec 2005    Post subject: Reply with quote
Do you know much about the honda bros? Its a single side swingarm, and the chain is tighten via an eccentric (i think) bearing or so i heard.
Also i HAD to buy a special spark plug tool for the bike as it is a weird angle to get into and no other spark plug tool i tried fitted, only hondas own. So im wondering if its the same with the chain tensioner, they do a specific tool for it, specifically for the bros
Dunno how long plates been in there, could be from new, abouit 20K miles on it now
RSheale
PostPosted: 23:30 - 13 Dec 2005    Post subject: Reply with quote
sorry then mr d i never knew that about the swing arm then so i am not so sure about that i thought it would be the same as my RS
quik_d
PostPosted: 23:41 - 13 Dec 2005    Post subject: Reply with quote
i've got a c spanner in the tool box, i'll give it a bash on saturday morning, leaves me saturday afternoon/sunday to get the honda part if i do in fact need it
quik_d
PostPosted: 23:53 - 13 Dec 2005    Post subject: Reply with quote
https://shop.wemoto.com/pictures.dyn?u=/pictures/hondaparts/chain-adjusting-spanner.jpg&i=25327&a=5828164
^^^^^ The official honda chain adjustment tool^^^^^
RSheale
PostPosted: 23:59 - 13 Dec 2005    Post subject: Reply with quote
7.50 for what looks like a broken bottle opener! there is no way i would pay that lol
have you nothing in your tool box that could do the same job?
the grim reaper
PostPosted: 10:58 - 14 Dec 2005    Post subject: Reply with quote
Be carefult about trying to use a suspension C spanner, the radius is different and it will slip and you will hurt yourself - DAMHIKIJKOK.
Cheers
Grim
quik_d
PostPosted: 22:07 - 14 Dec 2005    Post subject: Reply with quote
Dual purpose!
My dad seems to think it might be a worn clutch basket, theres no way around that is there? would it need a new one?
sickpup
Old Timer
PostPosted: 20:43 - 15 Dec 2005    Post subject: Reply with quote
Worn clutch plates.
Notched clutch basket.
second gear on the way out.
quik_d
PostPosted: 20:08 - 16 Dec 2005    Post subject: Reply with quote
Worn clutch plates.
= Bollocks Sad
quik_d
PostPosted: 20:12 - 16 Dec 2005    Post subject: Reply with quote
whats involved to sort it?
Sickpup your quite clued up on bros's and ntvs aren't you?
sickpup
Old Timer
PostPosted: 22:10 - 16 Dec 2005    Post subject: Reply with quote
Just a little.
New/second hand basket really but to be honest I'd just attack it with a file and smooth down the fingers.
New clutch. Not a hard or expensive thing to do. Make sure you get the metal plates as well tho.
Just had a thought. Take a look at the shaft that has the front sprocket on it and make sure the splines aren't damaged.
I might have a damaged engine with a clutch basket somewhere.
Second gear? wait for it to go, not much else you can do.
quik_d
PostPosted: 23:23 - 16 Dec 2005    Post subject: Reply with quote
damn it! just got the bike looking like i want it.
I'd rather not wait for it to go, i have to use the bike everyday to work and back and dont like the idea of losing a gear, even if 2nd gear is a short gear on it.
there was a clutch basket went for one on ebay few days ago as well, like £10 Sad Neutral
I'll whip the sprocket cover off and take a look tomorrow
The last post was made 20 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 84.71 Kb
