Yikes. Loosing a lot of water......
Josh|RD125LC
PostPosted: 22:33 - 15 Dec 2005    Post subject: Yikes. Loosing a lot of water...... Reply with quote
Took the RD out on its first run since the new crank etc, topped everything up, went about 15 miles, came back, checked the radiator and coolant bottle, and both were near enough empty! It did get very hot at one stage, had to pull over and let it cool. Held my hand over the exhaust, let some fumes hit it, pulled it away, and I had water on my hand. Confused
Now I checked all the hoses and connections, and they are all fine, no visible leaks. I can't really think what else it could be. There is a possibility that the head could be cracked, but I hope that isn't the case. Sad
Any ideas?
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
lilredmachine
PostPosted: 22:59 - 15 Dec 2005    Post subject: Reply with quote
head cracked or head gasket gone Neutral
I'm afraid those are the two options in this case. Check your oil for traces of white foam/scum, a sure sign that oil and water are mixing.
Edit: if it did get v.hot, it could have damaged the head gasket then, whilst you were riding it. Only problem is that if it did, it means the water is getting out/in via somewhere else.
PostPosted: 00:31 - 16 Dec 2005    Post subject: Reply with quote
Sounds like the head gasket is dead. Feel the radiator hoses after running it for a bit. If they are rock hard, this is your problem.
Head gasket would be my first port of call anyway on an LC 2-stroke. Not all that big a job. Check the head isn't warped before you fit a new one by putting it on a sheet of glass, it shouldn't rock about.
It can often be a very small 'jet' of gas escaping past the gasket into the water jacket causing these symptoms so inspect the gasket surfaces closely when you take the head off. If you see it, you know this was the problem. If there is no sign of a leak, the problem might be elsewhere.
Could also be caused by a knackered radiator cap.
the grim reaper
PostPosted: 09:18 - 16 Dec 2005    Post subject: Reply with quote
Before you do all this though, check that your radiator hoses aren't leaking at all. The water in your exhaust is possibly the normal amount but, if it is actually chucking out water, then I would also vote for head gasket.
Grim
Barry_M2
PostPosted: 10:32 - 16 Dec 2005    Post subject: Reply with quote
Its a 2 stroke, gearbox oil wont be effected by a head gasket leak.
Top everything up and fire the bike up. Leave it running til its all warmed up and upto operating temp. Take a look for leaks on all hoses and look at the rad for leaks too. Make sure the head and barrel are both torque'd down correctly.
Josh|RD125LC
PostPosted: 10:36 - 16 Dec 2005    Post subject: Reply with quote
I've just been told about this on the RD forum, and I can honestly say I can't remember the old man torquing up and head and barrell bolts. Confused
Think I better get him to bring the torque wrench home tonight. I just hope this solves it. The head gasket is brand new, so I couldn't see that as being the problem? Might have to replace it again now though.
RD125LC Pictures
Josh|RD125LC
PostPosted: 11:27 - 16 Dec 2005    Post subject: Reply with quote
Just taken the head off, and I can honestly say I didn't struggle one bit loosening the head bolts, two came off with ease, so Im guessing that was the problem. Head gasket is dead, split in 3 so need a new one again. But I screwed up a bit. I forgot to drain the water before I took the head off, so I hope to god that little or no water got in the crank casing. Doh!
RD125LC Pictures
Barry_M2
PostPosted: 11:51 - 16 Dec 2005    Post subject: Reply with quote
There you go, thats the problem. Most of the water would have gone out through the exhaust ports, the rings would have stopped most, if not all of it getting to the crank.
Sounds like an easy fix. Thumbs Up
Josh|RD125LC
PostPosted: 17:30 - 16 Dec 2005    Post subject: Reply with quote
Head is fine, not warped and no cracks. Think I may have to take the barrell off and check for water in the crank casing, if there is any then I'm going to need to soak it up. But the piston was near the top when I took the head off, so I doubt much water will have got past the piston?
RD125LC Pictures
Josh|RD125LC
PostPosted: 16:09 - 17 Dec 2005    Post subject: Reply with quote
Hmm we have the same problem again. Fitted brand new head gasket again, and this time torqued up the head bolts to what it says in the haynes manual. Topped up with water, and started it up. Same happened again, had water seeping through where the head meets the barrell. So off comes the head again. Close inspection sees that the head is in fact warped, so I get cracking with skimming it on sheet of glass with wet and dry paper, rotating it around and around in a circular motion. When all I saw was a shiney surface all round, I stopped. Got the old man out, he put silicon sealant on the gasket, put it on, and on goes the head as well. Top up the water yet again and start it up again. Tick over was fine, kept steady all the way, held hand over exhaust and it was just throwing out very fine dots of water, which I presume is whats left in the expansion chamber. So we leave it ticking over for 2 mins or so. Check the water level and its barely gone down, about a mm or two. Look down at the barrel and head, and what do we see, water seeping through again! At this point me and my dad are both baffled, and haven't a clue whats happening. Dad says that it must be the head, been skimmed to many times or something.
What do you think? Confused
RD125LC Pictures
PostPosted: 16:20 - 17 Dec 2005    Post subject: Reply with quote
Did you do the gasket surface of the barrel as well?
Josh|RD125LC
PostPosted: 17:59 - 17 Dec 2005    Post subject: Reply with quote
I gave it a quick going over with the wet and dry, was quite awkward to do so I didn't do it for long, just got all the crap off the surface.
RD125LC Pictures
PostPosted: 20:02 - 17 Dec 2005    Post subject: Reply with quote
I was just wondering if that gasket surface is a bit deformed/marked too. Might be worth giving it the glass plate treatment too?
cagiva gezzer
PostPosted: 15:25 - 18 Dec 2005    Post subject: Reply with quote
I used valve grinding paste and lapped the head and barrel against each other.
It's also a good way to tell where they are not meeting each other due to high/low points.
satans_BIG_helper
PostPosted: 15:48 - 18 Dec 2005    Post subject: Reply with quote
Hi Josh mate, is there any way u can get hold of a new or another head ? to try on there ? As i think you may be right it may have been skimmed one too many times and the surfaces are probably gone beyond tolernace so wont mate up too well...it might not be the head it may be the barrel thats a bit outta line ???
just my 2 pence worth....
Josh|RD125LC
PostPosted: 19:15 - 18 Dec 2005    Post subject: Reply with quote
Yeah I may just get another head from somewhere.
My dad was going to use the grinding paste method, but didn't have any left.
I just don't know what to do, whether to give the top of the barrell gasket surface a quick sand, or just find another head from somewhere.
RD125LC Pictures
Josh|RD125LC
PostPosted: 19:33 - 18 Dec 2005    Post subject: Reply with quote
Also forgot to mention, the past 3 days I have taken it out of the shed after being left in there overnight, I looked down at the carb, and have seen a large clump of ice at the end of the drain hose of the carb, happened 3 days in a row. Any idea whats causing that, and its iced up petrol obviously.
RD125LC Pictures
satans_BIG_helper
PostPosted: 19:39 - 18 Dec 2005    Post subject: Reply with quote
do you turn the petrol tap off at night ? if not i would do so Smile as its probably just where the bike is on a slope being parked on a side stand its running out the overflow ?
cagiva gezzer
PostPosted: 19:54 - 18 Dec 2005    Post subject: Reply with quote
You must be in a rather cold place. Not sure the exact temp, but the freezing point of fuel is at least -40 degrees C....
It's frozen moisture from the air forming ice as leaking petrol is evaporating and taking warmth with it. Just turn your fuel tap off.
Josh|RD125LC
PostPosted: 19:59 - 18 Dec 2005    Post subject: Reply with quote
I'm in Plymouth, and it hasn't really been that cold lately. Better turn the fuel tap off then. Just has never happened before. Strange.
RD125LC Pictures
The last post was made 20 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 113.47 Kb
