| goatblower |
 goatblower Two Stroke Sniffer
 Posted: 20:27 - 16 Dec 2005 Post subject: 1995 Aprilia Rx/RS125 ignition system |
can't find a replacement SEM coil yet for my RX125 so I'm going to try using a CDI system from a Honda C90 as per this article
https://www.btinternet.com/~jhpart/bkns125a.htm
I need to identify the wires coming from the bike's generator but can't get the fywheel off to take a peek.
I'm sure that the two yellows provide power for lighting etc. via a regulator which leaves me with a red, a green, and a black.
As I understand it there are two more coils in there, one producing 100 volts to power the ignition, and a pulser coil developing a couple of volts. The question is how do I connect to them? Is one of them earthed, are they both earthed? tried with a volt meter whilst turning the engine but can't be certain.
Help!!! does anyone know which is which?
thanks |
| goatblower |
 Posted: 18:29 - 17 Dec 2005 Post subject: |
The workshop manual does not say, but also gives nothing to check except resistance (no voltage to check with the engine cranking, etc) which suggests to me that it is a touch more complicated than you believe (if it was as you beleive it would be easy to usefully check the voltage over the coil).
If you ask Peter Knight on 0176 141 4106 he might well be able to help you.
I would mostly advise that you keep looking on Ebay. That coil about a week ago went for £7. The main failure point for this ignition system it the flywheel (magnets crack) and you will still be lumbered with that.
| goatblower |
| goatblower |
 Posted: 19:17 - 18 Dec 2005 Post subject: |
gettin carried away a bit there - only £50 from
https://www.skydrive.co.uk/sd_to_rs.asp !!!!!!
no one seems to list a £5 26x1.5mm - every other combination but that one! |
The last post was made 20 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
