Car - Reverse Gear
numark1
Scared of girls
PostPosted: 18:01 - 18 Dec 2005    Post subject: Car - Reverse Gear Reply with quote
I know its not a bike Laughing but whenever i put my car into reverse it makes kind of like a crunching noise. Sometimes it doesn't say i put it into reverse and it makes the noise i can then take it out and into neutral then back into reverse and it will be ok (with clutch down all the time)
Not sure what it is as its not a very health noise. My friend said it might be something to do with the rods whatever that is. Confused
Sometimes it doesn't even go into reverse. All the other gears are fine.
Barry_M2
PostPosted: 18:17 - 18 Dec 2005    Post subject: Reply with quote
Some car boxes are just like that. Not a Peugeot is it?
numark1
Scared of girls
PostPosted: 18:24 - 18 Dec 2005    Post subject: Reply with quote
Citroen so basically yes. Looks like im some tard when i put it into reverse. Laughing
PostPosted: 18:31 - 18 Dec 2005    Post subject: Reply with quote
Try giving it longer between putting the clutch pedal down and trying to select reverse.
LustyLew
PostPosted: 18:34 - 18 Dec 2005    Post subject: Reply with quote
I 'think' it's something to do with the the sprockets and the gubbin's in the gearbox rotating one way. Then when you put the car in reverse, they grind against each other before changing direction. That's why it usually happens when reversing into a parking space etc.
Nb
PostPosted: 18:51 - 18 Dec 2005    Post subject: Reply with quote
If its a saxo your clutch might need adjusting. Is your clutch pedal level with your brake pedal? Ive had to adjust my clutch once before because of this crunching into reverse.
numark1
Scared of girls
PostPosted: 19:22 - 18 Dec 2005    Post subject: Reply with quote
Will have a look tomorrow. Is it easy to do?? Lost the haynes. Confused
satans_BIG_helper
PostPosted: 19:45 - 18 Dec 2005    Post subject: Reply with quote
Piece of piss to adjust a clutch... i assume its a cable operated clutch if so u can either adjust it where it goes onto the engine usually very low down on the side of the engine. (pretty much same as a bike clutch)...... Or u might be able to adjust it on the back of the pedal... but involves putting ur head in on a weird angle n looking up Laughing its easy enuff done tho m8 Smile
MikeH
PostPosted: 22:12 - 18 Dec 2005    Post subject: Reply with quote
Just sell it and get a proper car instead of French crap Wink
Mike Mr. Green
Busa Junkie
binge
Emo Kiddy
PostPosted: 00:42 - 19 Dec 2005    Post subject: Reply with quote
Think Kickstart has hit the nail on the head with this one. Some cars are really bad at going into reverse.
My mini / was bad at going in, It grinded No matter what.
And sometimes, I had to put it into a gear before reverse or it wouldnt go in.
<|Ben|>
numark1
Scared of girls
PostPosted: 00:48 - 19 Dec 2005    Post subject: Reply with quote
I will give the clutch a fiddle tomorrow if my back is feeling better, if not i'll get klause to do it. Smile
If that doesn't work then i'll have to just leave it.
My car is cool. Cool Razz
0ddball
PostPosted: 00:59 - 19 Dec 2005    Post subject: Reply with quote
It's normal to an extent, not many cars have syncro on reverse.
ZXR750L
NC30UK
PostPosted: 01:06 - 19 Dec 2005    Post subject: Reply with quote
If you can feel it hasnt gone in, let the clutch up and try again. allways works perfect for me if i do that.
Rookie
PostPosted: 02:47 - 19 Dec 2005    Post subject: Reply with quote
You're not one of these scallies who puts it into reverse whilst it's still going forwards, are you? Razz
I've heard quite a few cars do this, it's just something that happens IMO, though I suppose it's a sign of gearbox wear.
The last post was made 20 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.71 - MySQL Queries: 15 - Page Size: 79.17 Kb
