| veeeffarr |
 veeeffarr Super Spammer
 Posted: 12:57 - 20 Dec 2005 Post subject: CG125 Suspension |
Hi,
My bike is a bit of a bumpy little fucker, I'm feeling every bump in the road, plus some I'm sure aren't there
On the springs at the back, there is a silver hoop (A bit like a giant nut) thas has various sized rounded grooves in... I take it I twist this to adjust the spring? What would I use to twist it, as there I no tools I can thing of that would grip the odd looking pattern across the top of it... Do I need to click it towards a shallower groove or a deeper one? (From the top of my head, they are both on the second longest groove)
Thanks for the help as always,
Toby |
| satans_BIG_helper |
 satans_BIG_helper Nearly there...
 Posted: 13:09 - 20 Dec 2005 Post subject: |
U can use a tool called a C spanner.... Or if ur like me.......... a Hammer and a Screwdriver
The longer the bit poking down on the shock the tougher the suspension will be as the spring(shock) is under more compression to start with....
etc....
ahhh feck it Stinkwheel put a proper explanation up i cant make sense today  |
| Nath |
 Nath World Chat Champion
| veeeffarr |
 Posted: 14:00 - 20 Dec 2005 Post subject: |
Cheers for that, softening it up will make it less bumpy? I will use one click per day until I find the setting I like  |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 15:49 - 20 Dec 2005 Post subject: |
| Toby R wrote: | Cheers for that, softening it up will make it less bumpy? I will use one click per day until I find the setting I like  |
That's the best way to do it. If you're regularly carrying about loads on the back, then a harder setting is better as the handling will be more normal with a load on, though it will be much harsher without as much load. On the hardest setting, expect the back end to spend as much time in the air as on the ground on a bumpy road.
On ours I believe there are five settings, setting it to the third notch works best. Softest wallows in sharp corners, you can feel the whole bike bouncing up and down when you're cranked over, which isn't very endearing. Equally hardest will bounce you about all over the place, but when I had 25 odd kg perched on the rack and pillion seat, it was (almost) fine.
https://www.rallydesign.co.uk/catalog/images/RD207.jpg
C-spanner (https://www.rallydesign.co.uk) ____________________ I must not be a troll...
Mmmm, Guinness
| veeeffarr |
| mchaggis |
| shammon |
 shammon World Chat Champion
The last post was made 20 years, 46 days ago. Instead of replying here, would creating a new thread be more useful? |
