| AntzRoweGSXR4... |
 AntzRoweGSXR4... L Plate Warrior
| Deano1 |
 Deano1 Borekit Bruiser
| AntzRoweGSXR4... |
| Groove |
 Groove World Chat Champion
| Misc |
 Misc World Chat Champion
| AntzRoweGSXR4... |
| AntzRoweGSXR4... |
| Andrewc2oo5zx... |
 Andrewc2oo5zx... Scooby Slapper
 Posted: 13:04 - 25 Dec 2005 Post subject: |
id burn it out and get a zxr400  ____________________ zxr's and cbr's
SUNDERLAND AFC |
| AntzRoweGSXR4... |
| AntzRoweGSXR4... |
| lilredmachine |
 lilredmachine World Chat Champion
| kb-zxr |
 kb-zxr Could Be A Chat Bot
| Nath |
 Nath World Chat Champion
| Misc |
| michaelryland |
 michaelryland Borekit Bruiser
| LUXY DJ |
 LUXY DJ World Chat Champion
 Posted: 12:51 - 26 Dec 2005 Post subject: |
id say keep trying with a push start in 1st or 2nd ____________________ GSXR750
(FAR FAR from standard) www.gixerjunkies.net |
| carvell |
 carvell Scuttler
| iDON |
 iDON Borekit Bruiser
 Posted: 13:06 - 26 Dec 2005 Post subject: |
Owning one myself, I can say they are hard to get at. Best is to remove the tank.
I have to say I have never changed a plug on these yet, but I know the pain into getting to them, specially on the middle cilinders.
HOWEVER.
The GSXR suffers from one BIG problem.
The (many) o-rings in the mikuni carbs, and mainly the one underneath the main jet.
I don't know which Mikuni noodlehead thought of this, but thing is, over the years these o-rings parish and will leak fuel around the mainyet, making the engine run too rich, which can lead to washing the bores (or something).
It's a known problem, which I learned on the very usefull 400greybike.co.uk forum.
Many people suffer from it. I have an occassional stall when I'm riding, so maybe mine need replacing too, but it's not as worse as some stories I've read.
But hard starting can mean many things. Since I have no garage, my bike is outside under a cover.
When I tried starting it 2 weeks ago, after having standing still for over a month (at least) it took me 15 minutes and too many pushed of the startbutton, before it finally fired up.
I guess it's better to drain the carbs, since the fuel can become bad or something.
I haven't tried, and in case you don't know, the P setting on the fueltab is for Prime, so you can fill the floatbowls without the engin running.
I guess this will help in starting up sooner. ____________________ www.idon-industries.com |
| doggone |
 doggone World Chat Champion
| meooo |
 meooo Nova Slayer
| BenBray |
 BenBray Spanner Monkey
 Posted: 20:51 - 26 Dec 2005 Post subject: |
If you know someone with a car, quids in.
If not, bump start it. Padle it down a hill like a mofo and give it all you've got, dont be a wimp
How long were you trying to start it for?! Drained the battery?! The battery should last longer than your desire to start the bike in vain!
Choke cable on my bike is naffed, so when I have to start it I pull the choke cable out, start it, and give it a little bit of throttle before letting it do its own thing. Then a bit of throttle when I stick the choke back in.
I still have no idea how managed to get yourself into this situation though. Thats mad. ____________________ Current Bike: nc30 |
| bidman |
 bidman Crazy Courier
 Posted: 16:13 - 27 Dec 2005 Post subject: |
Hi, I have owned 2 of the GK76A gsxr400's 1 of them is on my bikepics page. As already said getting to the plugs is a pain in the arse but not impossible. Once you have them all out, replace them as even though there may be a spark on the outside, you may have damaged the core which means it will not fire under pressure in the cylinder. Leave the tank off and plug holes open and turn over the engine to dry the cylinders out. Then replace the plugs and turn it over with no choke or throttle as with new plugs the spark will be good enough to ignite the slightest amount of fuel and get the engine running. Hope this helps Dan  ____________________ Don't ride it, RAG IT!! |
| AntzRoweGSXR4... |
The last post was made 20 years, 75 days ago. Instead of replying here, would creating a new thread be more useful? |
