Chain slack every 2 weeks?
shammon
PostPosted: 23:01 - 26 Dec 2005    Post subject: Chain slack every 2 weeks? Reply with quote
Im having to tighten the chain about every 2 weeks? what the hell i say is this normal (Honda cg) today it was slappin of the gaurd loud and had about 15cm playeach way! iv ordered a new front sprocket and chain but on looking the rear sprocket is a bit of centre on the rear wheel is seems to be buckled, i asume this is the cause? havent a clue guys & galls.
Andy
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
superstacker
PostPosted: 23:28 - 26 Dec 2005    Post subject: Reply with quote
Check the spindle is done up tightly!
mr.z
PostPosted: 11:24 - 27 Dec 2005    Post subject: Reply with quote
You need to replace front and back allways or your chain will wear super fast, meaning you'd be wasteing your money
With the new one check the allighnment carefully, check everything is done up propperly (torque wrench)
If a chain is wearing like that then its past its best anyhow, or horribly out of allignment, it shouldn't need doign that often till its buggered.
I'd suggest takeing it to a dealer and asking them to check the wheel for you, or go to a tyre place and get them to see if the wheel is balanced...
Good luck Thumbs Up
Stevie GooGs
PostPosted: 11:41 - 27 Dec 2005    Post subject: Reply with quote
i need to get new sprockets and chain on my CBR as the sprockets are worn badly also, how much have you got left to tighten? are both adjustments at the same length?
mr.z
PostPosted: 11:56 - 27 Dec 2005    Post subject: Reply with quote
Once the links are worn to an extent it will stretch in a cheese like way, then its time to change the lot!
shammon - Have you crashed the bike at all? or could it have been binned in the past?
PostPosted: 12:03 - 27 Dec 2005    Post subject: Reply with quote
Give your chain a good clean with something like parrafin then re-lube it. Pay particular attention to any 'tight links', work them back and forth with oil until they are moving freely.
Make sure the wheel is sitting square between the legs of the swinging arm. Best way to get a rough idea is to squat down behind the bike and look along the top of the chain, it shouldn't deviate to either side. Once this is square, run a straight edge (long bit of wood for example) along the length of the bike, it should touch the rear tyre at two points and be an equal distance from the front tyre at two points (with the steering held square). I usually use a piece of string like a builders level to check this. Adjust everything until it is perfectly square.
Once it is square, then adjust the chain tension. To do this find the 'tight spot' of the chain by feeling the chain tension as you rotate the wheel. Always set the chain tension at the tight spot. Slacken the wheel spindle and set the tension by moving each adjuster the same amount. Once you have it set, re-tighten the spindle and check the tension again (tightening the spindle sometimes has the effect of slghtly losening/tightening the chain).
If you are out of adjustment at any point, if there are any major tight links that wont loosen off or if the tight spot is so pronounced that the chain goes way too slack when you rotate the wheel away from it. Time for a new chain and sprockets. Likewise if you see any damaged/missing chain rollers or the teeth on the sprocket are badly hooked over.
shammon
PostPosted: 16:39 - 27 Dec 2005    Post subject: Reply with quote
Stripped it down today and the chain and sprockets are needing replaced, so much play on the rear sprocket you can lift the chain up on it slightly Confused
TimC
PostPosted: 18:37 - 27 Dec 2005    Post subject: Reply with quote
Im just after replacing the chain, front and rear sprockets on my cg. if the chain is streching after you tighten it replace it all, i intended to just get a new chain but after checking it all i found i did need a new set of sprockets, also when i was getting the chain i was advised to replace it all at once as putting a new chain on worn sprockets is slightly pointless.
The last post was made 20 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 57.83 Kb
