How do you remove a wheel with a side stand ?
MikeH
PostPosted: 22:51 - 27 Dec 2005    Post subject: How do you remove a wheel with a side stand ? Reply with quote
My KLE doesn't have a centre stand so whats the best way to support the bike to remove the rear wheel ?
Trolley jack and block of wood ?
Busa Junkie
T1z3R
PostPosted: 22:56 - 27 Dec 2005    Post subject: Reply with quote
im wondering the same thing as my bike doesnt have a centre stand now but i dont think i'd trust a jack since its all wheels.
buy a lift...they are about £30 from J&S
duck my sick!
Klause
PostPosted: 22:57 - 27 Dec 2005    Post subject: Reply with quote
When I didn't have my paddock stand I use to do this...
Get a block of wood and put it under the side stand till the bikes is almost upright, rather than lent over to one side. Now the bike is almost level, making it easier to jack up. Then just find a suitable place to jack the rear end up.
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
PostPosted: 23:12 - 27 Dec 2005    Post subject: Reply with quote
I use an ordinary car axle stand, but a piece of wood the right length will also do the job.
Put the bike on the sidestand. Squat down on the right hand side of the bike. Get hold of the parcel rack in your left hand and push up and away from you. You will notice the back wheel comes off the ground when you do this. Stick your stand/bit of wood under the swingarm and let the bike back down to rest on it.
Job done, remove wheel at your leisure. It is dead stable because you have three points of contact (block of wood, sidestand and front wheel).
You can do a similar thing with the front wheel but it is a bit trickier to lift due to the weight distribution. I hook the stand under one of the oval holes in the front of the belly pan. Turn the steering fully to the right, push up on the yoke so it takes some of the weight off the suspension (but not necessarily fully lifting the front wheel off the ground) and put the stand under. When you turn the steering back to the left, the wheel will come off the ground enough for you to remove it.
Of course, if you have a car jack, just put the bike on the sidestand and jack up under the right side of the swingarm to lift the rear or jack under one of the slots on the front right of the belly pan to lift the front.
MikeH
PostPosted: 23:48 - 27 Dec 2005    Post subject: Reply with quote
Thanks fellas.
I'll let you know if I drop it Shocked Confused
Mike Wink
Busa Junkie
Black Knight
PostPosted: 08:18 - 28 Dec 2005    Post subject: Reply with quote
You could buy a paddock stand for as little as £15. Keep your eye out for a used one, prob £5 or £10.
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
Kram
PostPosted: 09:51 - 28 Dec 2005    Post subject: Reply with quote
get a thick bit of pipe, about 12-14 inches long (that will reach the ground at an angle from your swinging arm)
place bike on side stand lean onto stand to make rear wheel rise, jam pipe between swinging arm and floor.
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
Saint Matt
PostPosted: 10:50 - 28 Dec 2005    Post subject: Reply with quote
If you have beams accross your garage you can use ratchet straps on the grab rail, or anything else suitable e.g luggage things, can't remember what they are called, the things the bungee straps go onto...you know.....those things
Finglonga
PostPosted: 14:43 - 28 Dec 2005    Post subject: Reply with quote
On my old KLR600 I used a Newcastle Brown Ale crate (donated by the local Off licence without his knowledge) . I just manhandled the bike onto it and Bobs your uncle. Wink
Andy Sez....
F.Y.Y.F.F.
The last post was made 20 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 60.4 Kb
