intake manifold replacing!!
puremagic72
PostPosted: 19:26 - 27 Dec 2005    Post subject: intake manifold replacing!! Reply with quote
short question, i need to replace the intake manifold on my nsr125,the part between the carb and engine, as the previous owner had broken it and just wrapped tape round it, i have bought a new one, and if i turn the fuel off at the tap, can i just take the old one out and replace??
or is there another thing i should do also??
Thanks Chaps,
Baz. Thumbs Up
Bezzer
PostPosted: 20:37 - 27 Dec 2005    Post subject: Reply with quote
What a piss-poor bodge, should go like a rocket with the new carb rubber on the way that is restricted Mr. Green
If you've got enough movement between the carb and the filter yes you can do it without shifting anything. If you can't get enough space just take the other end of the carb off the filter to give you more space, shouldn't have to take any cables off or upset anyything else. If the rubber is a very tight fit use silicone grease/oil(or something similar) to lubricate the rubber and it will fly on
puremagic72
PostPosted: 20:55 - 27 Dec 2005    Post subject: Reply with quote
but no petrol will piss out of it will it??
Thanks 4 quick reply.
Baz. Thumbs Up
PostPosted: 22:21 - 27 Dec 2005    Post subject: Reply with quote
If you turn the petrol off then you will limit the amount of petrol that leaks out. There is still some petrol in the carb (and some in the pipe from the fuel tank to the carb). This will spill if you take the carb off carelessly.
If you unbolt the airbox from the frame you will probably be able to move it far enough back to enable you to get the carb out of the way and then the remains of the carb mounting rubber out of the way.
Finglonga
PostPosted: 14:46 - 28 Dec 2005    Post subject: Reply with quote
You could always turn the petrol tap off and run the engine untill it cuts out, that should leave the float bowl almost (if not) empty. Wink
Andy Sez....
F.Y.Y.F.F.
Dom_
Points Mean Prizes
PostPosted: 18:27 - 28 Dec 2005    Post subject: Reply with quote
/thefastandthefurious
Your lucky you didnt blow the welds on the intake!!!!
https://img497.imageshack.us/img497/320/animation16vy.gif
Sorry
fast_tzr
PostPosted: 19:16 - 28 Dec 2005    Post subject: Reply with quote
feck me you'll gimme an epileptic fit!
The last post was made 20 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 52.53 Kb
