Wheel Bearing - Which Type
kb-zxr
PostPosted: 23:52 - 28 Dec 2005    Post subject: Wheel Bearing - Which Type Reply with quote
I need two rear wheel bearings and I have two options
2RS (double rubber sealed), or ZC3 (single metal shield)
Which is the best to use, and why (is there any noticable difference in use/life?
Thanks (ZXR400L in case that helps, for rear wheel)
I've been told rubber is maintanence free, so would be better, yeah?
Just thought I'd double check before getting them Smile
sickpup
Old Timer
PostPosted: 00:09 - 29 Dec 2005    Post subject: Reply with quote
2rs
kb-zxr
PostPosted: 00:11 - 29 Dec 2005    Post subject: Reply with quote
Thanks, I was pretty sure it was that, I been told by other ZXR owners, but I check my wheel and its got ZC3 in it at the moment Confused
PostPosted: 00:47 - 29 Dec 2005    Post subject: Reply with quote
Probably why it needs a new set Wink .
2RS are more resistant to water. Others will do in a pinch, but do not expect them to last anything like as long unless there is a seperate seal fitted.
sickpup
Old Timer
PostPosted: 01:26 - 29 Dec 2005    Post subject: Reply with quote
I've seen a few new Kawasaki's with the metal shielded bearings.
PostPosted: 11:57 - 29 Dec 2005    Post subject: Reply with quote
They also seem to use totally unshielded bearings in some areas, such as sprocket carrier bearings.
The last post was made 20 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 48.13 Kb
