| Rob W |
 Rob W World Chat Champion
| McJamweasel |
 McJamweasel BCF Junkie
 Posted: 11:49 - 30 Dec 2005 Post subject: |
The battery is dead and the clicking is the starter reay.
Get the battery on charge.  ____________________ BCF: Be yourself, just don't be an arse. |
| Rob W |
 Posted: 12:01 - 30 Dec 2005 Post subject: |
Thing is I charged the battery only 2 days ago, and the ignition is staying fairly bright when I try and turn it over, normally when the battery was dead all the ignition lights would go really dim as soon as you pressed the starter button.
Is it possible that the battery is fcuked? Seeing as I've charged it 2 times in the last month, and it seems like it needs another go today.
 ____________________ TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 RR-W Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900 |
| G |
 G The Voice of Reason
| Black Knight |
 Black Knight World Chat Champion
 Posted: 15:57 - 30 Dec 2005 Post subject: |
LOL at G. Reflex you Rude boy!
Most likely is the battery mate, try and charge it, if you gat no joy with that, change the battery.
Have you got a multimeter? ____________________ Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code. |
| Teaman |
 Teaman World Chat Champion
| Rob W |
| Knowlsey |
 Knowlsey Scooby Slapper
| Rob W |
| stinkwheel |
 Posted: 16:24 - 30 Dec 2005 Post subject: |
| Knowlsey wrote: | if there is plenty of juice in the battery, do the norm and check connections are clean, its possibly the starter soliniod,thats what will be clicking, cross a screwdriver across the two connections and see if it turns over |
What he said.
The "small circular thing with a fuse at the back of it" is the solenoid which is a type of heavy duty relay. It has two big metal terminals on top of it. If you short between them, the starter motor should turn. If it doesn't, your battery is probably duff. If it does, your solenoid is probably duff. They are about the same as one another cost wise
Or you could try jump/bump starting it.
Of course, it would be an idea to check you tightened the battery terminals down properly and that they are clean etc. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
| MarJay |
 MarJay But it's British!
| Rob W |
| McJamweasel |
The last post was made 20 years, 79 days ago. Instead of replying here, would creating a new thread be more useful? |
