| faith183uk |
 faith183uk Nitrous Nuisance
| Groove |
 Groove World Chat Champion
| haGGard |
 haGGard Nearly there...
 Posted: 17:34 - 30 Dec 2005 Post subject: |
I'm confused Who told you this nonsense?  ____________________ chaff mans random tingz on loot
"Why dont you go and weld your face to a moving train, you sack of pus" - tobyr
"ROFL MY TOFFLE I AM TEH 1337 SPELLING MISTAKE FINDER!" - BikerBen |
| stinkwheel |
 Posted: 17:35 - 30 Dec 2005 Post subject: |
| kwacky |
 kwacky Nitrous Nuisance
I'm just glad I'm an old chuffer who doesn't have to worry about this stuff  |
| faith183uk |
| Barney |
 Barney Spanner Monkey
 Posted: 17:37 - 30 Dec 2005 Post subject: |
Pretty sure they only make 30bhp derestricted. I think most people with the restricted licence don't bother, i know mine are coming out when the weather clears up  ____________________ CG125|CB400SF|CBR600FX|Triumph Daytona T595|CBR929RR |
| stinkwheel |
| Milo |
 Milo World Chat Champion
 Posted: 17:48 - 30 Dec 2005 Post subject: |
That's correct...but if and when they ever go to weigh the bike then it's not going to be anywhere near it's dry weight as it'll have oil and fuel in there...plus some ballast if required.  ____________________ Shaft drives rule.  |
| faith183uk |
| Kickstart |
 Kickstart The Oracle
 Posted: 17:59 - 30 Dec 2005 Post subject: |
All depends on whose figures for weight and power you use, and whether that power figure is at the back wheel or the crank and whether it is a wet or dry figure.
Aprilia do not claim 33hp for the RS125 (never seen them claim any power figure for a full power RS125, the RS came out after quoting 125 power figures became politically incorrect in Italy). Best I have seen from a road test dyno is 28.5hp, but that is the early bikes with the larger carb. Probably knock 3hp or so off for the later ones with the smaller carb, and more again for the latest ones with a fairly restrictive exhaust.
Dry weight Aprilia claimed was 115kg. Weight quoted on the frame plates on some of them (presume wet weight) is 140kg (and for example the 2001 owners handbook quotes the "Weight ready for starting" at 139kg. Working on that basis they can have a shade over 30hp and be legal for someone who has just passed their test.
| Kickstart |
| faith183uk |
| Kickstart |
 Posted: 18:21 - 30 Dec 2005 Post subject: |
Well, as an example my RS125 should be mechanically the same as yours (mine is a 1993 one, 34mm carb, Rotax 123 engine). In the PB road test they made 28.5hp. So 4hp more from yours as standard seems a bit hopefull.
The later bikes (certainly a 2002 model) have a smaller carb (28mm rather than 34mm) and are (I think) detuned a touch to use lower octane fuel. Added to which it might well have an exhaust with a cat stuffed up the inside (depending on when it was made and for which market). As such they will be down on power. The loss of ~5hp from these 2 dyno runs is probably about right for that.
| 3806danny |
 3806danny Spanner Monkey
 Posted: 19:52 - 30 Dec 2005 Post subject: |
bcos of the power to weight ratio  |
The last post was made 20 years, 325 days ago. Instead of replying here, would creating a new thread be more useful? |
