who turns their fuel tap off?
T1z3R
PostPosted: 16:46 - 01 Jan 2006    Post subject: who turns their fuel tap off? Reply with quote
is it necessary? i've never had one before this bike and not sure if i should be doing it.
duck my sick!
Jamie.
PostPosted: 16:50 - 01 Jan 2006    Post subject: Reply with quote
ive never turned it off
KLR600
PostPosted: 16:51 - 01 Jan 2006    Post subject: Reply with quote
I turn mine off everytime I turn my bike off. I don't actually know why but it feels weird if I don't do it now.
<Take Cool Photos!>
TOM M
PostPosted: 16:53 - 01 Jan 2006    Post subject: Reply with quote
I used to have to with my RS125 otherwise the engine would flood.
Ive never turned it off on the zxr Thumbs Up
Now owner of a 1200 Bandit
mrchips
PostPosted: 17:13 - 01 Jan 2006    Post subject: Reply with quote
Only if there is a fault
Northern Irish? www.nibikers.com
pipnet11
PostPosted: 17:15 - 01 Jan 2006    Post subject: Reply with quote
Every time the bike os going to be stopped for more than 10 mins.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
tatters
Exxon Valdez
PostPosted: 17:17 - 01 Jan 2006    Post subject: Reply with quote
I can,t turn mine off, its under the tank Laughing
Nath
PostPosted: 17:27 - 01 Jan 2006    Post subject: Reply with quote
I don't turn it off as my bike uses a fuel pump.
Hard livin', hard luck.
Irezumi aka Reuben
Carrot Top
PostPosted: 17:34 - 01 Jan 2006    Post subject: Reply with quote
I turn it off as otherwise it would flood the engine making it impossible to start. Rolling Eyes
Pictorgraphicalfantastical
cyberglass
PostPosted: 17:41 - 01 Jan 2006    Post subject: Reply with quote
i always turn mine off
i dident used to bother untill my engine flooded 1 to many times chucked a load of fuel into my exhaust and ended up splitting it down the seam when i started it Crying or Very sad
i then managed to blow a couple of big assed holes in it with a welder set to high Sad
as my bike is an import its hard to find a replacement exhaust so i had to rebuild using sheet steel (a twat of a job)
rode round on it for a few days with the hole in it sounded louder than a harley Mr. Green the neighbours loved it Razz
tatters
Exxon Valdez
Then The float in your carb is stuck if its doing that.
ZZR Girl
PostPosted: 18:08 - 01 Jan 2006    Post subject: Reply with quote
I don't turn mine off if it's being used regularly, but now that it's parked up over winter I've turned the fuel tap off.
Keep it shiny!
riichy
PostPosted: 18:12 - 01 Jan 2006    Post subject: Reply with quote
only when the tank is coming off.... Thumbs Up
.......... PLOD ............ zx636 2004
craigs23
Mr Muscle
PostPosted: 18:23 - 01 Jan 2006    Post subject: Reply with quote
Yep, all the time. It depends from bike to bike though. I found leaving the Blade's fuel tap on and attempting to start the bike flooded it (that'll be the fuel pump working overload then). Thought bad starting was down to a flat battery until I tried keeping the fuel tap off when the bike wasn't in use - cured the problem and starts on the button, even after a couple of weeks.
The RVF was quite happy to have its fuel tap on all the time; until I made a modification to remove the vacum feed. Like the Blade, I then had to turn it off when not in use to prevent non-starting.
Irezumi aka Reuben
Carrot Top
PostPosted: 18:34 - 01 Jan 2006    Post subject: Reply with quote
I know what's wrong, just havent sorted it.
It's a Suzuki GP125, an engine seal has gone which means gearbox oil gets into the cylinder anyway. The carb is situated on the right of the engine and the pipe keeps on slipping off a little, if you leave it on fuel builds up and drips out the bike a little, it also gets the spark plug damp.
Hence I carry a spare spark plug, just have to remove it leave the bike for 10 mins, kick it over a few times then put other spark plug in. Simple. Laughing
T1z3R
PostPosted: 18:42 - 01 Jan 2006    Post subject: Reply with quote
i havent been turning mine off but i've not used the bike that much yet to find out if it causes any problems.
i'll monitor it and see how it goes Thumbs Up
thanks for all your replies Very Happy
duck my sick!
thx1138
PostPosted: 19:23 - 01 Jan 2006    Post subject: . Reply with quote
I used to long ago, I don't now. I have mine set to reserve the whole time, and keep an eye on the trip meter to know when to fill up.
Aikman666
PostPosted: 19:41 - 01 Jan 2006    Post subject: Reply with quote
If your carb is all in working order, it shouldent need turning off. Personally i turn mine off all the time because i know how much of a bitch a flooded engine is. But ive considered starting to leave it on, the amount of times its cut out infront of people is rediculous. Whats even worse is when im sitting there screaming at it asking why it isnt working, then realise ive left the fuel tap off, but in the dark i cant find the feckin "on" position.
It would have anyone who tried to nick your bike miffed enough! They would make it half way down the street, bike would use up whats left in the carb, cut out, lock back wheel. Criminal then bins it and wahey, you've got your bike back (although maybe a bit damaged!) and hopefully the theif done himself a bit of damage in the process....Hooray!
Will work for petrol
My Design Blog
T1z3R
PostPosted: 19:42 - 01 Jan 2006    Post subject: Reply with quote
why would the back wheel lock after using all the fuel in the carb?
duck my sick!
Aikman666
PostPosted: 19:46 - 01 Jan 2006    Post subject: Reply with quote
Running out of fuel = no more engine movement
Assuming the clutch is still engaged and its not in a high gear (which he wouldent have time to get into) It would lock the wheel.
My Design Blog
T1z3R
PostPosted: 19:49 - 01 Jan 2006    Post subject: Reply with quote
oh...i only thought of a locked wheel as a result of brakes binding/chaing snapping and snagging it etc cos if you clutch in after running out of fuel then you'll coast.
duck my sick!
GearboxGeezer
PostPosted: 21:02 - 01 Jan 2006    Post subject: Reply with quote
I dont even have one, Im gessing it has some gizmo on it that does it automaticly
flat spot
PostPosted: 21:08 - 01 Jan 2006    Post subject: Reply with quote
Yes when it's away for the night. It doesn't necessarily mean the carb float isn't working because if the bike is on a side stand it's tipped over to one side and doesn't always stop the flow of fuel fully.
By the time the morning arrives it will be pissing out of the overflow.
Aikman666
PostPosted: 21:35 - 01 Jan 2006    Post subject: Reply with quote
Thats counting on you grabbing the clutch in time. Although now that i think properly, you would see the revs drop first, so you would need to be doing some high speeds to lock the wheel Thinking
My Design Blog
Jamie.
PostPosted: 22:04 - 01 Jan 2006    Post subject: Reply with quote
i cant see why or how the wheel could lock when you run out of juice??
The last post was made 20 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 124.52 Kb
