Anyone got a light?
mr.z
PostPosted: 14:48 - 02 Jan 2006    Post subject: Anyone got a light? Reply with quote
https://img492.imageshack.us/img492/4710/dscf00223zq.th.jpg https://img492.imageshack.us/img492/8296/dscf00234ek.th.jpg https://img492.imageshack.us/img492/1903/dscf00249ax.th.jpg
https://img492.imageshack.us/img492/4710/dscf00223zq.jpg
https://img492.imageshack.us/img492/8296/dscf00234ek.jpg
https://img492.imageshack.us/img492/1903/dscf00249ax.jpg
Just fitted the second pair, not wired up yet would have been done today but the place i buy wiring is closed*
The driveing lamps have been fantastic, i'm hopeing these can come on with the low beam when it really needs to (like in the rain at night with mrbmw pointing 250watts of main beam my way)...
Thought i'd share Wink
*The place i live is so very very lame, shops will close on the anniversary of somebody eating a particuarly nice pork pie. :/
0ddball
PostPosted: 15:01 - 02 Jan 2006    Post subject: Reply with quote
I pity the rabbit that gets caught in your headlights, you'll give it sunburn.
ZXR750L
lumphammer
PostPosted: 15:21 - 02 Jan 2006    Post subject: Reply with quote
At least it would be cooked before you hit it Very Happy Thumbs Up
Knowlsey
PostPosted: 19:17 - 02 Jan 2006    Post subject: Re: Anyone got a light? Reply with quote
250watts, i'd be carefull about adding them as driveing lamps, if you have 55front and 55 either side thats ok for driving lamps, but anything above that is classed as spot/fog lamps, fog lamps added to main beam switch and spots on a seperate switch, just thinking for MOT purposes thats all, not so much the copper, as most panda cars have no idea anyway
Finglonga
PostPosted: 20:03 - 02 Jan 2006    Post subject: Reply with quote
555w on main beam Wink 255w on dip. Twisted Evil
https://img.photobucket.com/albums/v112/finglonga/DSCF1296.jpg
Andy Sez....
F.Y.Y.F.F.
Jamie.
PostPosted: 20:13 - 02 Jan 2006    Post subject: Reply with quote
you didnt seriously do this did you? im sorry but i think it looks hideous
silverfox
PostPosted: 20:31 - 02 Jan 2006    Post subject: Reply with quote
thought it was a vespa!
Doddmaster
PostPosted: 21:07 - 02 Jan 2006    Post subject: Reply with quote
555w means it's drawing 46A, must have some beefy cables in the wiring loom!
Finglonga
PostPosted: 21:18 - 02 Jan 2006    Post subject: Reply with quote
Each pair of lamps have one heavy duty relay, each lamp has its own wire(fused) straight to the battery. All have 100w bulbs except the dip wich is still the 55w as I will be upgrading to HID soon Wink . Alternator can cope as bike has ABS and heated grips as a high capacity one is fitted as standard, but the battery is giving up. A new Hawker Odyssey battery on the way next week. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
mrchips
PostPosted: 21:32 - 02 Jan 2006    Post subject: Reply with quote
Absolute weapon.
Northern Irish? www.nibikers.com
Whosthedaddy
PostPosted: 21:37 - 02 Jan 2006    Post subject: Reply with quote
Where do you intend to go? Deep space? Into a black hole?
I have to agree, spots on a car to give it that rally look Confused , on a bike Thumbs Down
Whatever floats ya boat Thumbs Up
palmer
Fiddled Kiddy
PostPosted: 22:02 - 02 Jan 2006    Post subject: Reply with quote
pointless.
Finglonga
PostPosted: 22:06 - 02 Jan 2006    Post subject: Reply with quote
Personally I put them on my bike not for looks (the GS lacks them anyway) but......
A) the std head light is crap!
B) I do alot of night riding and I am sick of Numpties blinding me as 'I am only a motorbike with a single headlight'........its now payback time. Middle Finger
Could have done this but its a bit OTT! Mr. Green Shocked
https://www.advrider.com/forums/attachment.php?attachmentid=29315&stc=1&d=1063770446
Andy Sez....
F.Y.Y.F.F.
Whosthedaddy
PostPosted: 22:14 - 02 Jan 2006    Post subject: Reply with quote
Thats impressive Exclamation
mr.z
PostPosted: 22:46 - 02 Jan 2006    Post subject: Reply with quote
The bike went beyond hideious when the previous owner had the faring fitted in 1986, there not there for looks Wink
palmer wrote:
pointless.
Ever ridden a 20year old bike (with crap old lights) at night? Rolling Eyes
I'm with fingalonga on the night rideing, not so much for the blinding action (tempting) but it makes it all allot safer and all less pant fillingly scarey!
Knowlsey wrote:
The round ones are fogs, 55watt each, these are on the low beam only, switched and has a blue warning light (high beam into fog just bounces the light rick back at you)
The square driveing lamps come on with the main beam all the time.
Was fairly sure they would be ok? As they are mounted i dont think theyd pass an mot as the driveing lamps are slightly in the way of the fogs, to save the hassle i might just take them off for the mot Neutral Or do some rearrangeing...
mchaggis
PostPosted: 23:06 - 02 Jan 2006    Post subject: Reply with quote
You've not quite grasped the idea of the CX500 I see. Wink
I must not be a troll...
Mmmm, Guinness
Finglonga
PostPosted: 15:31 - 03 Jan 2006    Post subject: Reply with quote
I doubt you would fail an MOT because of that as the fogs are aimed more to the side than straight ahead, what they may fail you for is the suspension travel, It looks like the front mudguard may touch the lights on full compression? If they don't then just ignore me. Wink
BTW forgot to say the Fogs(bottom two lights) are on with sidelight and headlight and can be turned off if required, the driving lights are on with main beam. I can also have the fogs go out when I go onto main beam and on again when I go back to dip. Shocked Hence the birds nest of wires behind the clocks. Shocked
Andy Sez....
F.Y.Y.F.F.
SoND
PostPosted: 19:31 - 03 Jan 2006    Post subject: Reply with quote
Finglonga wrote:
That thing is f**king scary Shocked Shocked
mr.z
PostPosted: 22:13 - 03 Jan 2006    Post subject: Reply with quote
Finglonga wrote:
... Hence the birds nest of wires behind the clocks. Shocked
Tell me about it, when i switch on the ignition the relays in there sounds like a tapdanceing class.. When i first got the bike i had to rewire the whole front cause it was a propper mess! Confused At least yours was tidy before you started Razz
The clearance.. i'm pretty sure it will be fine (mesured it against max travel), if it did bottom out i'd have bigger problems i think Shocked
555watt is a heeeell of allot of current draw! didn't realise any bike alternators output so much! Keep your oil tot he max level, supposedly it helps a put-upon alternator stay happy Thumbs Up
DEN MONKEY
PostPosted: 11:52 - 04 Jan 2006    Post subject: Reply with quote
I luv it Thumbs Up
meh
gimpy limp
PostPosted: 12:57 - 04 Jan 2006    Post subject: Reply with quote
A good place for fogs for me I found was attached either side of the radiator, looks pretty menacing the spacing of them like that at night aswell
https://img488.imageshack.us/img488/9553/imag01443fq.jpg
(I had only wired up the left side when I took that pic)
The only other time it can look quite good I think is on those police type bikes with the big perspex screens that sit over the headlight and the 2 fogs either side.
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - sam.barwick@ntlworld.com
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
gimpy limp
PostPosted: 13:10 - 04 Jan 2006    Post subject: Reply with quote
Get the insulation tape out if you want to give it a more rally feel Cool
https://img494.imageshack.us/img494/5264/dscf00249ax8fi.jpg
DukeRed
PostPosted: 13:36 - 04 Jan 2006    Post subject: Reply with quote
Where csn you buy these? Would be perfect for my hack.
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
mr.z
PostPosted: 13:48 - 04 Jan 2006    Post subject: Reply with quote
That actually looks bretty cool Cool Was thinking of makeing a wire guard, dont think it need it but woudl look good..
Dukered - Vehicle wiring products sell them but i got mine from a local car parts shop, the likes of halfrauds do them but have a look in smaller places and you'll get them cheaper (i payed £15 for the driveing lamps and £18 for the fogs)
Finglonga
PostPosted: 15:02 - 04 Jan 2006    Post subject: Reply with quote
Jeebus!!!!! Got mine from Demon Tweeks just looked to find the link and the price has doubled on the fog lamps! Shocked Shocked
Anyhoo heres the links.....
FOGS (black ring)
Driving lamps FF50's (not blue)
The light bar was made by a guy in Belgium out of laser cut s/steel..
https://img.photobucket.com/albums/v112/finglonga/DSCF1403.jpg
and yes I know the bike needs a good clean, its called character. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
The last post was made 20 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 137.16 Kb
