carbs iceing up
3806danny
PostPosted: 20:58 - 02 Jan 2006    Post subject: carbs iceing up Reply with quote
cant find that sikolene pro-fst stuff,will redex do any thing?
divuk83
PostPosted: 21:04 - 02 Jan 2006    Post subject: Reply with quote
Not really, how can you not find the silkolene stuff, its sold almost everywhere.
https://www.710supplies.com/shop/imagesprod/silk/proFST.jpg
I have had a number of problems with my bike running in the cold. I had the valves done and a problem with my fuel pump fixed and its sorted now. When was the bike last serviced?
Dave
3806danny
PostPosted: 21:10 - 02 Jan 2006    Post subject: Reply with quote
ive only had 5 days the oil isnt black yet,will redex do any thing about the carbs freezing?
sickpup
Old Timer
PostPosted: 21:17 - 02 Jan 2006    Post subject: Reply with quote
Doesn't your bike have carb heaters?
3806danny
PostPosted: 21:28 - 02 Jan 2006    Post subject: Reply with quote
yeah but dont know how to taest them they look clean?
divuk83
PostPosted: 21:37 - 02 Jan 2006    Post subject: Reply with quote
If you don't know about how to fix it take it to a garage. I said this about your runner when you had a similar problem with it and you kept posting daft threads about it. Its all seeming very similar to the last time you had a problem!
https://bikechatforums.com/viewtopic.php?t=70450
https://bikechatforums.com/viewtopic.php?t=70363
https://bikechatforums.com/viewtopic.php?t=70375
I didn't ask about oil, I asked about valve clearances, if wrong they will make your bike run badly and cause problems similar to what you are having.
As I already said, redex is not the same as pro FST.
Dave
3806danny
PostPosted: 21:39 - 02 Jan 2006    Post subject: Reply with quote
redex aint the same but will it help 2 stop the fuel freezing?
divuk83
PostPosted: 21:59 - 02 Jan 2006    Post subject: Reply with quote
Its not the petrol thats freezing, thats not what carb icing is.
And for the 3rd time redex does not do the same as Pro FST.
Dave
sickpup
Old Timer
PostPosted: 22:29 - 02 Jan 2006    Post subject: Reply with quote
This is what I mean. You're not trying to find a solution or even bothering to check whether things are working.
A standard answer to almost any running problem in the cold on this forum is carb icing which is why I made the pisstaking comment in one of the other threads Get over it and have a look at the bike. It could even be a partially blocked tank filter or a stuck float valve flooding the engine when you slow or an inefficient vacuum tape closing up on idle after a heavy run.
So many things.
The last post was made 20 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 59.68 Kb
