would a low battery make my bandit cut out?
Bike Chat Forums Index -> The Workshop via View Category
3806danny
PostPosted: 20:20 - 01 Jan 2006    Post subject: would a low battery make my bandit cut out? Reply with quote
on idol?
satans_BIG_helper
PostPosted: 20:30 - 01 Jan 2006    Post subject: Reply with quote
If ya battery is bolloxed it could cause that..... are you having to jump start the bike ?
3806danny
PostPosted: 20:39 - 01 Jan 2006    Post subject: Reply with quote
it starts on the button it just started to die at the lights and did it wouldnt start had to push it off the road waited a minute then she did? only had it 3 days
PostPosted: 20:49 - 01 Jan 2006    Post subject: Reply with quote
Doesn't sound like the battery to be honest. Takes a hell of a lot of power to crank the engine over compared to just keeping it running.
3806danny
PostPosted: 20:53 - 01 Jan 2006    Post subject: Reply with quote
could it of flooded some how?
satans_BIG_helper
PostPosted: 20:56 - 01 Jan 2006    Post subject: Reply with quote
Maybe some water in the carbs ? or a blocked fuel line ?... sticking choke ?
Exactly how did it die ?
Was it running rough/choppy, intermitent firing or just suddenly die ?
Deffo not battery if it starts off the button..
3806danny
PostPosted: 21:01 - 01 Jan 2006    Post subject: Reply with quote
as soon as i pulled up it got a little bit rough then cut out,then it wouldnt start had 2 push it off the lights,the bike it self is a late r reg with 14000 miles and is mint,the bike only has 1 mark which i did on first day of riding
PostPosted: 21:04 - 01 Jan 2006    Post subject: Reply with quote
Possible it has flooded, but not likely normally. Choke sticking (the cables on the Bandit can stick and snap)? Fuel on prime?
My 1200 was a pain once with a similar issue. Turned out a needle valve was sticking. Found out when I left it on prime and it dumped 3 gallons of petrol through the carbs into the airbox and engine overnight.
satans_BIG_helper
PostPosted: 21:05 - 01 Jan 2006    Post subject: Reply with quote
Is the choke stuck on at all ?
I assume its the 4 bank of carbs with the pull out choke lever on it ?
Or Maybe low on fuel ?
Is it still doing it now or did it just happen the once Question
satans_BIG_helper
PostPosted: 21:07 - 01 Jan 2006    Post subject: Reply with quote
Damn u keith stop posting faster than me Laughing
3806danny
PostPosted: 21:14 - 01 Jan 2006    Post subject: Reply with quote
just once, i'll try the bike 2morrow hope fully its ok ? cheers
Lee_367
PostPosted: 23:28 - 01 Jan 2006    Post subject: Reply with quote
Might the cdi need a certain amount of power in order to work?
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
PostPosted: 00:44 - 02 Jan 2006    Post subject: Reply with quote
Yes, but far less than the starter motor needs to operate.
LustyLew
PostPosted: 21:31 - 02 Jan 2006    Post subject: Reply with quote
I had a very similar problem especially now in the cold weather.
My Bandit would slowly just die when idling. I noticed the bike was idling at about 800rpm, the manual says 1,100-1,200 rpm is recommended.
Slightly OT, would a race can affect the idle speed? I never had a problem when I had the road can on for the MOT.
3806danny
PostPosted: 21:37 - 02 Jan 2006    Post subject: Reply with quote
i think my carbs are freezing, dont know how 2 test the heaters,would redex do any thing? the can might b letting it breath 2 much?
PostPosted: 23:31 - 02 Jan 2006    Post subject: Reply with quote
Yes it would. At idle the amount of air going through the carbs is tiny and tiny changes in the system can have a major effect. Quite likely that just changes in the weather can have a similar effect.
sickpup
Old Timer
PostPosted: 00:09 - 03 Jan 2006    Post subject: Reply with quote
You had the problem because it was running lean.
The oil pump on these engines doesn't start working at the right pressure until 800-900rpm so not only did you have the chance of seizing due to running lean but also as your oil pressure wasn't high enough.
LustyLew
PostPosted: 00:34 - 03 Jan 2006    Post subject: Reply with quote
Oops!
Oh well, I've sorted it all out now anyway. Let's just hope I've not done too much damage. Not really ridden it much as it's been untaxed etc for the past 5 months.
The last post was made 20 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Workshop via View Category All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 98.21 Kb
