Still not fast enough
rg 250 freak
PostPosted: 11:11 - 03 Jan 2006    Post subject: Still not fast enough Reply with quote
hi all
just a quick one how far can i go with my mixture screw still lacks power but has more now i have adjusted again now 2 1/2 turns out can i go further
please help it driving me crazy and costing me money
thanks
Full throttle all the way
PostPosted: 12:18 - 03 Jan 2006    Post subject: Reply with quote
The mixture screw only affects the mixture at tiny throttle openings. It will have no real affect at large throttle openings which will be when you are noticing the lack of power (assuming you are using more than 1/8th throttle Wink ).
Get a selection of main jets and try those. Also try lifting the needle a notch.
Set the mxture screw back to standard and work from there for throttle response just off a closed throttle / on idle.
Best way I can think of describing it is that trying to adjust the full throttle mixture using the mixture screw is like trying to adjust the temperature of the oven when baking a cake by adjusting the central heating thermostat.
PostPosted: 12:25 - 03 Jan 2006    Post subject: Reply with quote
Good analogy Thumbs Up .
rg 250 freak
PostPosted: 23:51 - 03 Jan 2006    Post subject: Reply with quote
Thanks kickstart
i did try with the needle but it had no affect that i felt any way do i have to combine needle mix and jets to get a better balance
The last post was made 20 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 41.12 Kb
