oil drain plug please help
lee125
PostPosted: 13:17 - 03 Jan 2006    Post subject: oil drain plug please help Reply with quote
i have a kmx 125 and today i went to give it an oil change for the first time since i bought it and i started to unscrew the oil drain plug and it goes a bit loose but does not come off even after about half an hour of trying to unscrew it i think it might be stript does anyone have any ideas on how i can get it out will be much appreciated
finpos
PostPosted: 16:19 - 03 Jan 2006    Post subject: Reply with quote
If it's rotating, grab the plug with pliers or mole grips and pull on it whilst unscrewing it. It should come out.
Good luck getting it back in, though, sounds like the threads have stripped.
I've not seen one for a long time, but It's possible there's a magnet in a cage attached to the back of the plug which is there to catch bits of errant metal. Sometimes this cage distorts for some reason and won't come through the hole even though the plug itself has freed itself from it's threads. In which case pulling very hard is the only solution.
finpos.
lee125
PostPosted: 17:37 - 03 Jan 2006    Post subject: Reply with quote
thanks mate got it out and got the sump rethreaded thanks for the help Very Happy
The last post was made 20 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 34.86 Kb
