earth??
mbk ovetto good or bad???
good
16%
 16%  [ 1 ]
bad
83%
 83%  [ 5 ]
Total Votes : 6
bharbutc
PostPosted: 16:11 - 03 Jan 2006    Post subject: earth?? Reply with quote
where would i find the earth on the frame of my mbk ovetto ??
where abouts on the frame would it be?? please help
Suzuki
Roger
PostPosted: 16:13 - 03 Jan 2006    Post subject: Reply with quote
"The earth" tends to be underneath it.
Same with most things on the planet. Wink
If you meant the electrical earth, then any part of your frame will do.
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
doggone
PostPosted: 18:32 - 03 Jan 2006    Post subject: Reply with quote
I suppose it has a battery?
Follow the black lead from battery negative terminal - it will be attached to the frame somewhere - this is known as the 'earth'.
When anything is switched on the current flows through the 'device' e.g lights, and back to the battery via frame then earth lead.
A simplification but gives you the idea.
cathawhitt
PostPosted: 22:23 - 03 Jan 2006    Post subject: Reply with quote
your frame acts as the electrical earth - if ya get a set of indies ya can test them by taking the positive from your battery direct to the positive lead to the bulb and taking the other to the frame. It has to touch the metal though not the paint!! Any bolt that goes into the frame and touches directly to the metal can be used for an earth lead!
riichy
PostPosted: 22:25 - 03 Jan 2006    Post subject: Reply with quote
should be near the - on the battery ......i think Confused
.......... PLOD ............ zx636 2004
The last post was made 20 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 2.46 - MySQL Queries: 15 - Page Size: 44.95 Kb
