| veeeffarr |
 veeeffarr Super Spammer
| Compo |
 Compo Nova Slayer
| Knowlsey |
 Knowlsey Scooby Slapper
| veeeffarr |
| Knowlsey |
 Posted: 22:28 - 03 Jan 2006 Post subject: |
If it wasn't doing it before, adjusting the shock isn't going to fix it unless you have been messing with the settings (which is unlikely if you don't have a c-spanner). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| veeeffarr |
| Knowlsey |
 Posted: 22:55 - 03 Jan 2006 Post subject: |
Use the tyre pressures recommended in the owners manual. Put a bit more in if you are heavily loaded.
Having overly soft tyres is a common cause of handling problems. As has also been said, the roads are in shite order at this time of year so keep it smooth. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| shammon |
 shammon World Chat Champion
 Posted: 23:08 - 03 Jan 2006 Post subject: |
Toby im on 29 front 33 rear as i am a fat Bas*ard but check the tyres i started getting slip especialty at the start of roundabouts? prob of all the crap on the road. result is a new rear tyre the back was worn enough to question how much grip was in the centre.
remember if the road glitters where are the gritters, take it easy
Andy ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
| veeeffarr |
 Posted: 23:17 - 03 Jan 2006 Post subject: |
| shammon wrote: | Toby im on 29 front 33 rear as i am a fat Bas*ard  but check the tyres i started getting slip especialty at the start of roundabouts? prob of all the crap on the road. result is a new rear tyre the back was worn enough to question how much grip was in the centre.
Andy |
Hi,
I'm 11 stone, 6 foot, think manufacturers settings should be alright for me, might put an extra PSI in each.
Yeah I was coming to a roundabout in the right hand lane, when there was a lorry PARKED in that lane (Insane I know) so I moved to the left to pull out, looked right before I go past the lorry, nothing there, got past the lorry, looked out, royal mail van caining it round so I braked quite harshly, que slipping around like a mouse on hot butter. |
| T1z3R |
 T1z3R World Chat Champion
 Posted: 23:34 - 03 Jan 2006 Post subject: |
have you checked the tread on the rear tyre?
it took a guy at work to point out to me the my lowly kymo was in need of new shoes but i hadn't realised before and i'd been riding the bike for a year i did begin to wonder why it was slightly unstable under braking in damp conditions  ____________________ duck my sick! |
| veeeffarr |
| veeeffarr |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 00:25 - 04 Jan 2006 Post subject: Michelin M45 |
I got a rear of these on my little Hongdou. So far so good, no complaints, plenty of grip and neutral handling. Mind you, I am comparing it to a squared off almost bald plastic Chinese tyre. Cornering with that was fine up to a point, when you suddenly dropped over the edge of the square. Replacing it was one of the better things I've done to that bike.
https://two-wheels.michelin.com/2w/front/affich.jsp?codeRubrique=2092004104135&codePage=2092004104135_10092004123534&lang=EN
https://two-wheels.michelin.com/2w/ImageServlet?imageCode=3005&codeSite=LP2R
A rear cost me £42 fitted with a new tube from my mechanic, other places wanted between £47-55. That is if you're looking for a new rear tyre. First I'd check for any loose nuts and bolts. The front end braking went a bit odd and I ignored it. After a while it started clunking and making braking with the front really quite scary. I had a look and there was almost 5mm of clearance slopping about where the front wheel nut should have been tight.  ____________________ I must not be a troll...
Mmmm, Guinness
The last post was made 20 years, 81 days ago. Instead of replying here, would creating a new thread be more useful? |
