question on k&n filters
Scorpius
PostPosted: 03:58 - 04 Jan 2006    Post subject: question on k&n filters Reply with quote
I have a Cagiva Mito 125 and am thinking of upgrading the air filter to a k&n. Now I'm just wondering, if I upgrade from the standard will I have to adjust anything on the bike? Im asking because a mate told me i'd have to adjust the jetting or it would cut out if I did that! But another person i've spoke to has told me I wouldnt have to change anything else when putting a k&n in so im confused! Confused
Black Knight
PostPosted: 04:05 - 04 Jan 2006    Post subject: Reply with quote
The bike will run fine without jetting. Airflow will be increased but certainly not enough to cut the engine.
You could have it jetted for optimum performance or economy but to be honest the cost doesn't warrant the return.
Rick.
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
luigi
PostPosted: 12:55 - 04 Jan 2006    Post subject: Cagiva K&N air filter Reply with quote
Hi, Scorpius
Accordingly with Black Knight, i would adding a simple way to keep under control your engine.
It is the same way used by the 125cc Grand Prix rider in Worldwide Championships to check the last controls before a race.
-Choose a road (better if you make this on a track) where you can keep the gas wide open for 15/20 seconds at least WITHOUT ANY RISK FOR YOUR LIFE
-After this time close completely the gas, pull the clutch and shut off the engine.
-Stop the bike, with engine shut off keeping always the clutch pulled, using only the brake
-Once stopped check the spark plug; the insulator of the electrode must be coloured of a light brown for a correct air/fuel ratio.
- If darker the engine don't have risks but can give more power.
- If clearer the situation is dangerous FOR YOU AND YOUR ENGINE that need a jet increasing.
-MORE THE COLOUR, FROM LIGHT BROWN ARE NEAR TO WHITE,
MORE THE JET INCREASING ARE URGENT AND THE SITUATION ARE DANGEROUS.
Remember that results are affected by the air temperature, the kind of spark plug, the rider weight and the Octane Number of the gasoline used .
Anyway, if you have changed only the air filter, this system can let you sleep sufficiently quiet dreams.
Ciao,Luigi
veeeffarr
PostPosted: 12:58 - 04 Jan 2006    Post subject: Re: Cagiva K&N air filter Reply with quote
luigi wrote:
Hi, Scorpius
Ciao,Luigi
Thanks for the post, something everyone should know!
Scorpius
PostPosted: 13:44 - 04 Jan 2006    Post subject: Reply with quote
Cheers Black Knight and Luigi esp. Thats good info you got there Thumbs Up will give it a go.
PostPosted: 14:14 - 04 Jan 2006    Post subject: Reply with quote
There is a fair chance that just sticking on a K&N individual filter would cause it to run lean, and 2 strokes often react to running lean by seizing.
The description above of how to do a plug chop is good, and well worth trying. However probably worth increasing the main jet size a bit and working down from there (a few main jets are cheap, but a new piston and replating the barrel isn't cheap).
Safest to have the jetting slightly on the rich side, otherwise you might be fine until the weather changes.
bidman
PostPosted: 17:58 - 04 Jan 2006    Post subject: Reply with quote
Why? All you have to do is ride up the road and back let it cool and check the plug colour, not sure what the reason for the clutching and the throttling off etc... is??
Dan
Don't ride it, RAG IT!!
bish777
PostPosted: 18:11 - 04 Jan 2006    Post subject: Reply with quote
i dont think it would be that drastic for a replacement filter, but raising the needle by one clip would probably do the trick and be safe to prevent seizing.
GSXR1100J
PostPosted: 18:50 - 04 Jan 2006    Post subject: Reply with quote
Riding up and down the road will not tell you much. About the best it will do is give you some idea of the idle mixture, which is not that important and is easily adjusted.
The idea of the routine given above is to find out whether it is rich or lean on the main jet. You want somewhere so that you can hold it on full throttle / high revs for some time (normal solution is to find a long fairly steep hill). When you want to stop you pull the clutch and hit the kill switch at virtually the same time so that the plug colour is not affected by the mixture at lower revs / throttle openings as you slow down. If you just shut the throttle and slowed down you would at best just get a very poor plug reading, more likely a reading of the idle mixture adjustment.
bidman
PostPosted: 18:55 - 04 Jan 2006    Post subject: Reply with quote
fair enouigh Thumbs Up Razz
Flip
PostPosted: 20:29 - 04 Jan 2006    Post subject: Reply with quote
I haven't read the entire thread but it does advise on the K&N site not to rejet just use their filters.
sickpup
Old Timer
PostPosted: 11:18 - 05 Jan 2006    Post subject: Reply with quote
Yes but they fib.
Also this chap means one of those ramair filters that bolt straight to the carb and do away with the airbox.
The last post was made 20 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 76.79 Kb
