| LustyLew |
 LustyLew World Chat Champion
 Posted: 09:36 - 04 Jan 2006 Post subject: Bandit Idling |
Right, I thought I'd sorted my ide speed problem out. But it appears not!
Every time I come to a stop, the bike dies. I've located the idle screw, but the manual says I should adjust this when the engine is hot? When the engine's hot, it's burning my hand! So I can't really adjust it easily.
Does anyone know, if I am looking at the idle screw from the RIGHT side of the bike, which direction I should turn it to increase the idle speed?
I also think that I will put the legal can back on, I have a feeling this isn't helping matters, oh and it's too damn loud for early morning.
Thanks for your help as usual.  ____________________ Like a Yorkie - I'm not for the girls  |
| Bezzer |
 Bezzer World Chat Champion
| LustyLew |
 Posted: 10:52 - 04 Jan 2006 Post subject: |
Hmm, very odd.
This is apparantly the idle screw. But it seems to be under the carbs? ____________________ Like a Yorkie - I'm not for the girls  |
| Bezzer |
 Posted: 11:13 - 04 Jan 2006 Post subject: |
OOps sorry slip of the brain, should have said under not over. Mine comes out straight not under like that one and is on the left. ____________________ I used to be indecisive but now I'm not quite so sure. |
| sickpup |
 sickpup Old Timer
| Bezzer |
| LustyLew |
 Posted: 15:06 - 04 Jan 2006 Post subject: |
Well,
I think I've sorted it. Let the bike warm up for 10 minutes. Then used the adjuster. Didn't do very much, so I adjustted the tension and the throttle, I think the cables must have been a bit slack. That would also explain why it is a bit slow off the lights etc...
Thanks for all your help guys! Much appreciated!  ____________________ Like a Yorkie - I'm not for the girls  |
| Brava210 |
 Brava210 Crazy Courier
 Posted: 17:34 - 04 Jan 2006 Post subject: |
There is supposed to be a"small" amount of slack in a throttle cable,you are not really supposed to adjust idle speeds by "tightening the cable"-if thats what you did ....idle should be adjusted mechanically at carburettors..
Gary
ps hope that didn't sound patronising.  ____________________ Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE"
| Bezzer |
| Brava210 |
 Posted: 21:03 - 04 Jan 2006 Post subject: |
I agree with you Bezzer I used to set up my montesa like that but on full lock it used to raise the idle because the cable was too tight..  ____________________ Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE" |
| LustyLew |
 Posted: 22:01 - 04 Jan 2006 Post subject: |
I think it was a combination of the two. When I went to ride hoem after work, I tweaked with the idel adjuster and the revs dropped again. The reason I adjusted the play was that it was taking a good 100mm turn before I got enough power to get going at a reasonable pace.
I'm still not 100% convinced, but it's running and not a lot I can do until the weekend when I can work on it in the light. I think I'll be replacing the legal can at the weekend until I can spare the cash for a dyno jet kit and the time (and knowledge) to set it up properly.
Cheers for all your comments tho, has been nice to know I'm not on my own lol! ____________________ Like a Yorkie - I'm not for the girls  |
| bish777 |
 bish777 World Chat Champion
The last post was made 20 years, 66 days ago. Instead of replying here, would creating a new thread be more useful? |
