motorway riding for a newbie
tpp
PostPosted: 19:04 - 04 Jan 2006    Post subject: motorway riding for a newbie Reply with quote
I bought a kawasaki Z 750 two weeks ago.
been on the the bike about 12 times, mainly in town and the odd dual carriageway ( speed around 65,70 mph)
took the bike on the M40 between wycombe and denham
got up to 70 and the bike felt it was snaking or moving from side to side a couple of inches,
my mate says the rear tyre is really square and could cause this
the tyre is Bridgestone bt012
can anyone explain it to me,or i am just panicking because i am not used to motorway riding ( it was touching cloth material) by the way i am 42 and drive a car and passed my das
Bendy
Mrs Sensible
PostPosted: 19:06 - 04 Jan 2006    Post subject: Reply with quote
You got a flyscreen or anything non-original on it?
R4nger
PostPosted: 19:15 - 04 Jan 2006    Post subject: Reply with quote
This should be in the newbie section Razz
bish777
PostPosted: 19:18 - 04 Jan 2006    Post subject: Reply with quote
bikes can follow the ruts in the road left by lorries-try the middle lane or stick to the centre of the left lane.
Lighter bikes suffer worse. My FJ1200 barely noticed them, but my GSXR is badly affected by ruts.
GSXR1100J
tpp
PostPosted: 19:21 - 04 Jan 2006    Post subject: Reply with quote
Normal screen that comes with the bike, although i have just bought a vario screen
Rookie
PostPosted: 19:29 - 04 Jan 2006    Post subject: Reply with quote
Is this not just aquaplaning? What was the weather like?
tpp
PostPosted: 19:35 - 04 Jan 2006    Post subject: Reply with quote
Weather was dry ,the road appeared dry
there was no wind,except from a*se
nrml76
PostPosted: 19:38 - 04 Jan 2006    Post subject: Reply with quote
Was this mainly when decelerating using engine braking? If so it could be due the torque. Use the brakes to slow down instead and it should disappear. This is not so much of a problem on smaller bikes such as those used for DAS training. You notice it when you hop onto a big bike directly from DAS.
kwacky
PostPosted: 19:40 - 04 Jan 2006    Post subject: Reply with quote
a BT012 is a very soft compound. It'll square off quickly.
Rookie
PostPosted: 19:41 - 04 Jan 2006    Post subject: Reply with quote
Yeah if it was dry I'd check out your tyre, and your tyre pressure.
tpp
PostPosted: 19:56 - 04 Jan 2006    Post subject: Reply with quote
Would a square tyre cause this
the tread is thin in the centre and has a few wear bumps
Mongrel
PostPosted: 20:16 - 04 Jan 2006    Post subject: Reply with quote
A badly squared tyre may cause this....by I'd be more inclined to look at tyre pressure personally.
Did it worsen with speed or weight shift?
As has already been pointed out you can 'track' in the ruts you can get along the inside lane caused by lorry tyres repeatedly compressing the same bit of tarmac.
tpp
PostPosted: 20:18 - 04 Jan 2006    Post subject: Reply with quote
it got worse the quicker i tried to go ,and that was only up to 70
yes iwas in the inside lane
kwacky
PostPosted: 20:29 - 04 Jan 2006    Post subject: Reply with quote
sounds like you need to change your rear tyre
xploitation
PostPosted: 20:41 - 04 Jan 2006    Post subject: Reply with quote
[quote="bish777"]bikes can follow the ruts in the roadquote]
i know what you mean!!! was going alone to day when my bike drifted to the right! looked down and my wheels were in the grove between the new and old tarmac!! give me a fright!! Laughing
Piaggio NRG MC3 "Put the headphones in, Lid on and pull away"
BIKE FUNDS-----?-600
CBT-Done THEORY-Not Booked TEST-Not Booked
PostPosted: 20:42 - 04 Jan 2006    Post subject: Reply with quote
A lot of the GPZ/GPX series kawasakis were known for getting a bit twitchy feeling on a worn (<2mm) front tyre too. Don't know if yours is the same.
Shouldn't be getting a speed wobble at that sort of speed in any case. Check tyre pressures and tread depths. Also might be worth checking wheel alignment, and seeing if the steering head and wheel bearings have any play in them.
PostPosted: 20:46 - 04 Jan 2006    Post subject: Reply with quote
Something else that you might not be aware of since you did direct access is that some heavy vehicles trail a mass of 'dirty air' behind them. I find box vans, skip lorries and tankers are the worst. If you get into the vortex of air coming off the back of them, the bike can land up being all over the place.
You never learn about this properly until you have had to ride about on a 125 for a long time, using the slipstream of the wagons to give you a 'tow' up to the heady heights of 68mph. Wink
Finglonga
PostPosted: 21:01 - 04 Jan 2006    Post subject: Reply with quote
Shocked Tankslapper Alert Shocked
Mr. Green
Andy Sez....
F.Y.Y.F.F.
greenmeanie
PostPosted: 21:11 - 04 Jan 2006    Post subject: Reply with quote
try stiffening the rear shock. if it is too soft it will cause the bike to move about especially noticable at speed. Thumbs Up Mr. Green
Rh.
Barney
PostPosted: 21:14 - 04 Jan 2006    Post subject: Reply with quote
I tried this and it deffo made a difference for the better, But still feel like im getting bashed around without any screen, your neck gets used to it after a while.
CG125|CB400SF|CBR600FX|Triumph Daytona T595|CBR929RR
Shaun
Likes 'em bent
PostPosted: 21:23 - 04 Jan 2006    Post subject: Reply with quote
If you aren't doing 120mph by the end of the slip road you're a pussy.
Wave2k
G's Stalker
PostPosted: 22:02 - 04 Jan 2006    Post subject: Reply with quote
what about when you hit your 115mph restrictor Razz
Ducati 1299 Panigale
2009 Corvette C6 z51
tpp
PostPosted: 22:09 - 04 Jan 2006    Post subject: Reply with quote
i wonder if the copper in the unmarked car will take the same view
as he hands me my automatic ban.
my licence gone my bike gone , and thats if im one piece
Shaun
Likes 'em bent
PostPosted: 22:12 - 04 Jan 2006    Post subject: Reply with quote
Jeeze lighten up it's a joke, although I do try it every time anyway. Wink
Irezumi aka Reuben
Carrot Top
PostPosted: 22:16 - 04 Jan 2006    Post subject: Reply with quote
Although you said there was no wind something to watch out for, connected to stinkwheel's large vehcile scenario is gust's of wind catching your hand/hand's. A large gust will catch you unaware and push your hand back, something to be wary of.
Pictorgraphicalfantastical
The last post was made 20 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 124.64 Kb
