MALOSSI GEAR KIT 6711297
gardner.jake
PostPosted: 23:21 - 04 Jan 2006    Post subject: MALOSSI GEAR KIT 6711297 Reply with quote
I purchased one of these gear kits today and went back and tryed to fit it to my scooter (suzuki katana lc) i got the gear box thingy open and i cant seem to see any possible way that this can fit. it came with a cog and a shaft with a cog on. does the shaft with the cog on replace the thing that my wheel connects to. thts the only way tht i could see it going but then there is no disk brake spline and i have no idea where the cog goes. if anyone can help then the product code is 6711297. p.s the malossi instructions are bollux.
gardner.jake
PostPosted: 23:28 - 04 Jan 2006    Post subject: oil Reply with quote
now that i have emtyed out the oil then whether the gear kit can be kitted or not then i am going to need to put new oil into the gear box thingy. what sort of oil do i need to put into it.
bidman
PostPosted: 11:15 - 05 Jan 2006    Post subject: Reply with quote
Hi to fit the gear kit you need a 5 ton press to firstly slide off the old cog then to push the new 1 on. Also u will need to press a new bearing onto the shaft that already has a cog on it. The wheel needs to be taken off and the shaft knocked back through the casing so you have all the shafts and gears out then replace the ones that you have upgraded. If you have to ask which ones to replace then maybe you should be letting a garage do it Confused
Dan Thumbs Up
Don't ride it, RAG IT!!
The last post was made 20 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.3 - MySQL Queries: 13 - Page Size: 35.56 Kb
