NSR 125
Geobhoy
PostPosted: 21:12 - 05 Jan 2006    Post subject: NSR 125 Reply with quote
i have a nsr 125 and was heading to work doing 80 on the by-pass when my back wheel locked up it then released itself and locked up again does anyone have any ideas what would cause this fustrating problem HELP!!!!!!!!!!!
satans_BIG_helper
PostPosted: 21:24 - 05 Jan 2006    Post subject: Reply with quote
you have just had your first experience of a seizure... Sad
Check the oil lines and tank make sure it has 2T in it...
HAve u recently added a exhaust or different air filter ? or carburettor ??
The barrel, and or piston could have suffered damage from this too
TS 50er >CG 125>AR 125>TZR250> z200(shit heap)> ZXR750 H2 > VT500 FT >XLR250 > Mito125mk1 (unlucky strike) > TZR250 3ma > GS550 > TDR250 > GSXR750 >GS1000 > Elefant 650 > GPZ750 > FZR600>z1000 (03) > KTM 640 LC4
(Yeah i forgot some too :S )
Geobhoy
PostPosted: 21:30 - 05 Jan 2006    Post subject: Reply with quote
it was my first lock up but there is pently of 2 stroke in it and oil however i haven't check the oil lines nothing new has been added to it and i know the engine hasn't seized because i tried to bump start it but it wstill wouldn't start
satans_BIG_helper
PostPosted: 22:16 - 05 Jan 2006    Post subject: Reply with quote
it wasnt a full seizure mate it just nipped up basically a tiny seizure but there has to be something causing it....
Have u changed spark plug recently ?
alains
PostPosted: 22:30 - 05 Jan 2006    Post subject: Reply with quote
it should be more likely a lean mixture or a badly adjusted oil pump . to correct the mixture upjet your carb , clean and oil your air filter . using the pilot screw has no effect at high revs .
take off your plug and compare the colour with this link https://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
then have a good look at your oil pump
prior restarting ,by the plug hole ,drop a coffee spoon of oil , pass the 2nd gear and move the bike several wheel turn . then put a new plug and go gently for a while
Geobhoy
PostPosted: 22:07 - 07 Jan 2006    Post subject: Reply with quote
No I have't changed the spark plug i didn't think that it would have casued the back wheel to lock?
Saint Matt
PostPosted: 23:12 - 07 Jan 2006    Post subject: Reply with quote
Nipped a ring mate, by the soundsof it you don't know how to fix it, so I'd take it to a garage chap Smile
The last post was made 20 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 50.39 Kb
