| shager |
 shager Scooby Slapper
 Posted: 22:26 - 06 Jan 2006 Post subject: WHATS WRONG WITH MY HONDA CG125 |
MY HONDA CG 125 STARTS BUT EVEN WITH OUT MY HAND ON THE THROTTLE IT REVS THE FUCK OUT OF IT, ALSO THE THROTLS HAS GOT NO SPRING BACK ON IT BUT THAT IS NOT THE PROBLEM FOR THE REVING, IF ANY ONE COULD HELP ME AT ALL IL BE VERY GREATFUL |
| Retro-Man |
 Retro-Man Traffic Copper
| shager |
| stinkwheel |
 Posted: 22:44 - 06 Jan 2006 Post subject: |
Sounds to me like the throttle valve has stuck in the open position or had been put back in the wrong way round.
Other possabilities include a stuck throttle cable or the throttle needle having come adrift from the valve (it is held in place by a pretty flimsy clip).
Has anyone been messing with the carburettor recently?
I would be unscrewing the top of the carb, inspecting the throttle valve assembly and checking the throttle cable is moving correctly. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| shager |
 Posted: 23:01 - 06 Jan 2006 Post subject: |
my mate took it apart the outher day and it hs not worked properly since could you please tell me in detail how tyo solve this problem thanx  |
| shager |
| dodger |
 dodger Traffic Copper
 Posted: 23:15 - 06 Jan 2006 Post subject: |
You should also give your caps lock button a service aswell, as it seems to be stuck in the ON position  ____________________ My Bikes: Piaggio NRG| Aprilia RS 125| Suzuki GSX-R 600|Yamaha Fazer Ducati 848
Europe 2008 |
| shager |
| -Savage- |
 -Savage- World Chat Champion
| shammon |
 shammon World Chat Champion
 Posted: 23:37 - 06 Jan 2006 Post subject: |
Check the throttle adjuster under the throttle handle and adjust it back fully to its start.
Now do the same for the actual carb adjuster which you undo the lock nut and screw it down fully, now adjust the the throttle adjuster under the handle bar again and set it to a sensible bite point (so you just pull it back to increase speed) if its still reving badly then its the carb
If the carb has been out and messed with, then expect time for it to be fixed right, they are robust but do have parts which are easily buggered if its been in the hands of an inexperienced person.
As above the fourm members have some top advice here and will help you to sort out your prob the more info the better, try to get the manual it helps so much in avoiding mishaps and saves ££££.
All the best ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
| stinkwheel |
 Posted: 00:08 - 07 Jan 2006 Post subject: |
If you unscrew the top of the carb (should be finger tight) and pull straight up, you will remove the throttle valve assembly still attached to the cable.
I reckon this has been put back in the wrong way by your mate. As you look at the throttle valve you will see there is a groove along one edge. This should fit over a 'tag' inside the carb which is on the right hand side of the carb.
So, you need to slide this assembly back in so the tag engages in the groove and so the throttle needle slides down into a small hole in the bottom of the carb (the main jet). When you have it in the right position, it should just drop in and you should be able to screw the cap back on without having to compress the spring any more than a couple of centimetres. To do this sucessfully it should be placed back in the carb absolutely vertical with the groove exactly facing the right hand side of the carb.
You should not need to force anything. Be very careful not to bend the throttle needle or damage the point of it. Keep everything very clean.
EDIT: The 'groove' and 'tag' arrangement might be on the left or the right side depending on the model of bike. At the bottom of the throttle valve you will see an angled cutaway. This should face backwards. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| bidman |
 bidman Crazy Courier
 Posted: 00:17 - 07 Jan 2006 Post subject: |
Hi, the chances are your mate has less of an idea than you do and has probably simply turned the idle screw all the way in so the bike idles ridiculously high. Its a flat headed screw that goes in the right hand side of the carb and raises the needle the more it is screwed in, check this first before taking apart the carb, Dan ____________________ Don't ride it, RAG IT!! |
| Jamie. |
 Jamie. World Chat Champion
| mchaggis |
 mchaggis World Chat Champion
 Posted: 03:16 - 07 Jan 2006 Post subject: |
Having produced exactly your problem before, I'd agree with Stinkwheel.
Unscrew the top of the carburettor, and make sure the ramp is resting on the idle speed screw, not the slot. Turned through 180 degrees it can also go in as there is a slot cut in the slide to allow the cable to be installed. That results in the needle being far too far above the jet, so there is no restriction to the fuel flow -> wheee!.
Everyone with that type of carb must do it at least once I reckon.
Merely turning the idle speed screw far too far wouldn't remove the spring back from the throttle, the increase in height just isn't enough. Putting the slider in backwards so it is much higher than it should be does.
If you'll forgive the simplistic nature of my drawing and the slight inaccuracies (e.g. airflow left to right rather than out of the page at you and the idle screw having the main jet wide open), then the attached diagram shows the potential problem. Turn the throttle assembly (assy.) through 180 degrees and its base sits on the idle screw, far too high. Screwing the idle screw in lifts the throttle assembly so more fuel is let out of the needle jet, so the engine revs higher at idle. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| shager |
 Posted: 17:30 - 09 Jan 2006 Post subject: |
thanx every one i sorted it it was the needle not put bak right in the carb  |
The last post was made 20 years, 171 days ago. Instead of replying here, would creating a new thread be more useful? |
