| jinxy88 |
 jinxy88 Nova Slayer
 Posted: 19:18 - 07 Jan 2006 Post subject: Aprilia RS125 Oil Leak Problem |
Well I have been working on the RS125 and nearly ironed out all the small problems with it that BCF has helped me out with. Even took it for a spin today and seemed to be working fine.
Problem is I keep getting this re-occuring oil leak which only seems to start when the bike is warm and I havent much of a clue what the problem is and not sure if I want to attempt it.
Below are some pictures from the workshop manual that I used to show where the oil is leaking from:
https://i31.photobucket.com/albums/c369/jinxyrs125/leak.jpg
The bike seems to be running ok apart from this leak, but I do not want to ride it in case it causes more damage so any ideas on what is causing the leaks or some advice from some more mechanically minded people would be great!  |
| bidman |
 bidman Crazy Courier
 Posted: 19:59 - 07 Jan 2006 Post subject: |
Hi, looks to me that the gasket has gone on the engine casing, replace this and it should be ok.
Dan ____________________ Don't ride it, RAG IT!! |
| Kickstart |
 Kickstart The Oracle
 Posted: 23:55 - 07 Jan 2006 Post subject: |
Leak from the bottom may well be the gasket. Check it isn't the oil drain plug, or possibly one of the plugs on the clutch cover leaking (the ones for adjusting the clutch).
Not sure why it is pumping oil out of the clutch cable. Only thing I can think of is the gearbox is getting pressurised. Possibly from the gearbox being overfull, or possibly a leaking clutch side main bearing seal.
| jinxy88 |
 jinxy88 Nova Slayer
 Posted: 00:43 - 08 Jan 2006 Post subject: |
Ok, thanks for the pointers.
I have heard same things for explainations of why it is leaking like it is but I think it may be a job for the garage this one... but will post back once the problem is fixed. |
There is a gap of 7 years, 93 days between these two posts... |
| keltow |
 keltow L Plate Warrior
 Posted: 02:19 - 09 Apr 2013 Post subject: |
7 years have passed.... (and no answer )
I have exactly the same problem and this is the only website on google which discusses the problem.
I read the comments, so I replaced all the gaskets and oil seals.
The clutch cable is still leaking oil... It also leaks when the engine is turned off while it is still hot.
Could there be a vacuum accumulating in the gearbox ?
If so, How to get rid of it.
Did I mess up replacing the gaskets (again?) and I have to do it again ?
If so, how can I make sure the gaskets are installed correctly. There isn't much to do wrong, is there ?
I always use a small amount of liquid gasket on the paper gaskets.
There is aprox. 600cc gearbox oil. |
| stirlinggaz |
 stirlinggaz World Chat Champion
| Robby |
 Robby Dirty Old Man
| keltow |
 Posted: 21:57 - 16 May 2013 Post subject: fixed |
I had to fix my computer so I lost this forum. But I found it
I hate to see a topic not having a solution to the problem.
Fixed!
I made a small video about the mistake made.
There was an engine leak not from the gaskets but from the ''seals''.
Explained in video:
https://youtu.be/SYUxFVJQ3Ug
I hope this would help others with the same problem
There is a gap of 6 years, 80 days between these two posts... |
| sakke68 |
 sakke68 L Plate Warrior
The last post was made 6 years, 251 days ago. Instead of replying here, would creating a new thread be more useful? |
