| loply |
 loply World Chat Champion
 Posted: 15:37 - 08 Jan 2006 Post subject: Electrical problem (electrics turn off when i turn the bars) |
Hi folks,
I took the tank of my bike today to service the carbs, and on putting the tank back on I ran the engine for a while, gave it a few revs, etc. Got my gear on and started wheeling the bike out the garage when it cut out - The starter motor wouldnt even turn.
Turns out that the electrics (lights, starter, everything) die when the bars are in a certain location. If you get them set right the bike will start, but it will cut out as soon as you move the bars.
I tried blindly unplugging and replugging wires around the clocks, but it made no difference. Could it be the ignition barrel/lock itself?
Whats the normal procedure for fixing a problem like this? I can forsee it being long and frustrating unless somebody knows a good method.
Could it be caused by something shorting on the forks or steering rather than a wire coming loose?
Cheers,
Rich ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| Finglonga |
 Finglonga World Chat Champion
| stinkwheel |
 Posted: 16:19 - 08 Jan 2006 Post subject: |
Agreed. Inspect the wiring loom where it goes past the headstock, the insulation can wear away and cause a short. You might also have trapped a wire under a plastic or under the tank. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Guest |
 Guest Brolly Dolly
 Posted: 16:26 - 08 Jan 2006 Post subject: |
What they ^ said - you know what the problem is, and where it is. All you have to do now is find it
Could even be a connection that 'looks' good but is being pulled just enough to break when you turn the bars.
I've had these in the past - they're character building  |
| loply |
| -Savage- |
 -Savage- World Chat Champion
| Finglonga |
The last post was made 20 years, 69 days ago. Instead of replying here, would creating a new thread be more useful? |
