Engine not starting; Clicking noise; dimming neutral light;
OnyxAvalution
PostPosted: 18:46 - 09 Jan 2006    Post subject: Engine not starting; Clicking noise; dimming neutral light; Reply with quote
When i try to start my suzi GS125('89) up the neutral light will dim a lot and itll make a fast clicking noise before completely dying. Ive checked the battery, and the voltage is fine. Does anyone know what the problem might be or what i could do to narrow down the cause?
Thanks.
Brava210
PostPosted: 18:52 - 09 Jan 2006    Post subject: Reply with quote
check the battery voltage while trying to start it,if it falls below 10volt on cranking the battery is knackered.
Gary
Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE"
PostPosted: 19:39 - 09 Jan 2006    Post subject: Reply with quote
Yep, classic symptoms of a gubbed battery. Give it a charge up and try. If that doesn't work and it will bump/jump start, buy a new battery.
extreme3d
PostPosted: 19:42 - 09 Jan 2006    Post subject: Reply with quote
Agreed, it will be the battery. The clicking noise is just the relay, nothing mechanical so relax!! If the neutral light is coming on then there may just be enough power to bump start the thing if you need to get some where.
magnamaniac
PostPosted: 21:53 - 09 Jan 2006    Post subject: Reply with quote
Yep, a real case of SDB (Sudden Death Battery)
I'm no braniac, rather a maniac
OnyxAvalution
PostPosted: 01:06 - 10 Jan 2006    Post subject: Reply with quote
I bought a new battery a little while ago, and it seems to be fine. I will check the voltage when i try to start it up though just to check.
Ive tried bumping it a few times, and it doesnt seem to have enough power to do it.
What other tests whould i do on the battery to check it?
luderacer
PostPosted: 09:03 - 10 Jan 2006    Post subject: Reply with quote
have u cleaned all connections? also wires to the altonator, grounds etc if they are dirty or not making proper contact a good batter one matter
Gazdaman
I did a trackday!!!
PostPosted: 12:38 - 10 Jan 2006    Post subject: Reply with quote
You need to check the voltage while there's a decent load across it.
I doubt there's anything that'll draw a decent enough current in your garage, but my dad used to use a small electric fire, then check the voltage.
But anyway, it's classic knackered battery.
Gaz
The last post was made 20 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 54.68 Kb
