CLUTCH NOT WORKING
lee125
PostPosted: 21:56 - 09 Jan 2006    Post subject: CLUTCH NOT WORKING Reply with quote
hi i have a 1976 yamaha dt175 and i have just rebuilt the engine and i have done this using the manual but know its all putback together the clutch isnt working when you pull the clutch lever in it doesnt clear the gear at all can someone please help as i want to go on it and get the piston worn in any answers on this will be much appreciated
White Noise
Mr Dudwee
PostPosted: 22:02 - 09 Jan 2006    Post subject: Reply with quote
is the clutch adjusted properly?
WN
Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight
lee125
PostPosted: 22:10 - 09 Jan 2006    Post subject: Reply with quote
yes the cable is adjusted to as tight as it can go
sickpup
Old Timer
PostPosted: 03:42 - 10 Jan 2006    Post subject: Reply with quote
IIRC there is an arm that disengages the clutch. This hasn't been fitted properly as you fitted the clutch cover. You need to wind it on.
Sorry not much help but it has been 12 years since I built one of these.
The last post was made 20 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.9 - MySQL Queries: 13 - Page Size: 38.8 Kb
