| MikeyC |
 MikeyC World Chat Champion
| Suzuki |
 Suzuki Roger
 Posted: 12:05 - 10 Jan 2006 Post subject: |
Chances are good.
Expect to pay about £35, or £55 ish for a top of the range one.
Get yourself an Optimate III too. ____________________ <Simple> no I'm shaven Jon
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
| LustyLew |
 LustyLew World Chat Champion
Chances of them stocking them are slim to none. Chances of them being able to order them are better. They have started to get into bike parts recently.
Not sure on delivery times or prices though. ____________________ Like a Yorkie - I'm not for the girls  |
| MikeyC |
| Suzuki |
 Suzuki Roger
 Posted: 12:09 - 10 Jan 2006 Post subject: |
Might just be old age. How old is it?
Also, battery life is largely dependant on the use of your bike. Lots of small journeys will knacker the battery a lot faster than using the bike once a week to do a 200mile trip.
If you have the tools (and you will if you've got the standard Suzuki toolkit under the back seat) it'll take you about 5 minutes to fit.
Remove the rider's seat (squidge back the back corners of it to get at the bolts), and you'll see the battery underneath.
Undo the bolts holding the battery connectors on, and undo the rubber clip. Battery slides out.  ____________________ <Simple> no I'm shaven Jon
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map |
| Annabella |
 Annabella Like a person, only smaller
 Posted: 12:10 - 10 Jan 2006 Post subject: |
| MikeyC |
| Suzuki |
 Suzuki Roger
| numark1 |
 numark1 Scared of girls
 Posted: 12:14 - 10 Jan 2006 Post subject: |
| MikeyC |
 Posted: 12:33 - 10 Jan 2006 Post subject: |
Thanks peoples!  |
 Posted: 13:01 - 10 Jan 2006 Post subject: |
Seems to depend on the particular branch of Halfords. Hopefully your local one is OK, and hopefully a GSXR battery is common enough for them to keep in stock.
Should be easy to fit. Just undo the earth cable first (this way if your screw driver slips while undoing it you will only connect the earth to the frame, and once that is out of the way you are not going to get sparks should the screw driver slip and connect the +ve terminal to the frame).
How old is the battery?
| MikeyC |
 Posted: 13:14 - 10 Jan 2006 Post subject: |
I'm pretty convinced a new battery was put in last year when I had my big service  |
| MikeyC |
 Posted: 14:23 - 10 Jan 2006 Post subject: |
Not from memory, no... on the odd occasion I turn the ignition on and leave it for less than a minute before firing it up, but thats all? I'm just hoping Halfords have one in, don't wanna call out the RAC again tonight with the same problem as this morning  |
| doggone |
 doggone World Chat Champion
| MikeyC |
 Posted: 15:28 - 10 Jan 2006 Post subject: |
Thanks for the advice.
Went to halfords, they don't stock any bike batteries. However, went to start the bike, it started on the button. I'm confused? Thought it'd be dead?  |
| Type_Mo |
 Type_Mo World Chat Champion
 Posted: 15:29 - 10 Jan 2006 Post subject: |
Just consider yourself luckily
Take it for a niice long spin when you get a change to give the battery a charge. ____________________ - Typhoon ?0 - Yamaha DT125R - Aprilia SR125 - Yamaha DT125R - Honda Hornet 600 - |
| LustyLew |
 Posted: 15:38 - 10 Jan 2006 Post subject: |
If it's been given a jump start then you've ridden it tow work, it may have charged up a little.
My car has a short somewhere and drains the battery if left connected for more than 24 hours. My current trick is to disconnect the positive terminal while Im not using it. Saves me having to jump start every time. ____________________ Like a Yorkie - I'm not for the girls  |
| numark1 |
 Posted: 15:39 - 10 Jan 2006 Post subject: |
Sometimes they recharge themselves a tiny amount so it will start. I think your battery is probably a Y9-8BS (something like that) should be quite a common battery.  |
The last post was made 20 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
