mounting pins question
apu180
PostPosted: 15:24 - 12 Jan 2006    Post subject: mounting pins question Reply with quote
i'm just in the process of changing the rear brake pads on my 1997 bandit 600...following the instructions in the service manual but i'm a little unsure of how to remove the brake pad mounting pins....can anyone tell me how?...thx
Guest
PostPosted: 17:14 - 12 Jan 2006    Post subject: Reply with quote
https://70.85.253.252/spst/1997%20GSF600S/42.gif
Prise off plastic cover #8
Remove retaining clip #7
Now wriggle out the two pins #6 which will cuse the two springs #5 to drop out.
The pins will more than likely be seized into the caliper body at the back (wheel side). I would seriously advise you buy two new pins before you start to strip it as you may have to butcher them to get them out.
Sometimes a squirt of WD and a pair of pliers will do the trick, some times you need to clamp a pair of mini moles in the middle to wangle them out.
It's even known to have to saw them in half or even remove the caliper completely, split it and them clamp the pin in the vice and 'screw' the caliper half off the pin.
A little heat from a plumber's blowlamp onto the back of the caliper where the blind hole for the pins is can help expand the metal and get them moving.
Or drill a small hole through from the back of the caliper to use a small drift to knock them through.
This is one of the most common and worst jobs on Suzukis - all for the sake of using mild steel pins instead of stainless.
apu180
PostPosted: 17:38 - 12 Jan 2006    Post subject: Reply with quote
thx alot for that....ive been soaking them in WD and i'm starting to thing theyre gonna need a good clobbering to get them moving....any idea where i can buy some new pins from?...thx again Smile
Guest
PostPosted: 19:48 - 12 Jan 2006    Post subject: Reply with quote
Any Suzuki dealer should stock 'em, they're a regular replacement item Wink
Part no. 69141 - 46E01
Bezzer
PostPosted: 20:57 - 12 Jan 2006    Post subject: Reply with quote
Correct and £4 each FFS Shocked...... or alternatively if you PM me for my address then send me a stamped(30p) addressed envelope I'll send you a pair of stainless pins for nowt Mr. Green
https://hometown.aol.co.uk/Mickcbr1100/BanditBling/StainlessPins2.JPG
The last post was made 20 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 43.66 Kb
