problem engine idling too high
Scorpius
PostPosted: 17:03 - 12 Jan 2006    Post subject: problem engine idling too high Reply with quote
I have a cagiva mito thats meant to idle at around 2000 revs. However recently when pulling up at traffic lights and junctions etc when i puill the clutch in or the bikes in neutral its revving at 3-4k revs Confused does anyone know why its doing this? the throttle lever is twisted all the way forward so its not a stuck handle.
alains
PostPosted: 18:05 - 12 Jan 2006    Post subject: Reply with quote
very often is a dammaged cable (fiber broken which sock the handle) but it can be also no play on your throttle .
cagiva gezzer
PostPosted: 18:09 - 12 Jan 2006    Post subject: Reply with quote
Thumbs Up But, carb's shouldn't go out of adjustment. Try the following instructions, if that doesn't work you might have an air leak.
Jamie.
PostPosted: 18:33 - 12 Jan 2006    Post subject: Reply with quote
it should not idle at 2000rpm, no way, its normally around 1-1500k
The last post was made 20 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 39.09 Kb
