Carb Jet + Needle Question
lllN30lll
PostPosted: 16:10 - 14 Jan 2006    Post subject: Carb Jet + Needle Question Reply with quote
after breaking my last carb i got another off Ebay (£4.99) Bargain Very Happy
went to change the carbs today, gave the one from ebay a good clean and noticed the main jets a different size to mine and also noticed the carb needle is slighty longer.
all my bike has is an allspeeds exhaust, airbox spout has been slightly drilled, and theres no airfilter (dont ask me why)
so, which Needle should i use? and which jet (either a 110 or 120)
cheers
PS it's a K reg NS125r
https://img.photobucket.com/albums/v707/lllN30lll/Photo-0045.jpg
Turbo R1
CRF450R
PostPosted: 17:20 - 14 Jan 2006    Post subject: Reply with quote
The needle position should be adjustable. Could just be that someone has moved the needle on yours (you adjust them by moving the clip on the top of the needle, further to the pointy end to richen the mixture in the mid range). Also I would be tempted to stick with the 120 main jet if that works at the moment.
Only odd thing is that the slide looks bigger as well on the picture you posted. Is the new carb a PHBH26 like the original?
lllN30lll
PostPosted: 17:22 - 14 Jan 2006    Post subject: Reply with quote
holding the carbs side by side they look exactly the same, i'll try the 120 jet but which notch should i set the needle at?
Turbo R1
CRF450R
PostPosted: 18:02 - 14 Jan 2006    Post subject: Reply with quote
Not sure if the 26 and 28mm carbs are the same body with just different machining. Check what is stamped on the side.
I would use the needle position that you old carb / needle is set to.
Richer is safer.
puremagic72
PostPosted: 18:25 - 14 Jan 2006    Post subject: Reply with quote
if it has 4 notch's, set it too the second from the top, if it has 5, set it on the 3rd.
All the best,
Baz. Thumbs Up
lllN30lll
PostPosted: 18:53 - 14 Jan 2006    Post subject: Reply with quote
i want to try to get rid of the splutter at 5000rpm though, will raising.lowering the needle help that?
so theres 5 notch's, top notch is richest? and lowest notch is the leanest? or is it the other way round?
Turbo R1
CRF450R
PostPosted: 20:14 - 14 Jan 2006    Post subject: Reply with quote
Top notch is the leanest, bottom notch is the richest. Basically using the top notch the needle sits slightly lower. As it is tapered by being lower it is also thicker and so blocks off more of the fuel supply.
lllN30lll
PostPosted: 20:28 - 14 Jan 2006    Post subject: Reply with quote
cheers, i'll give it a go tomorrow and give it a plug chop
Turbo R1
CRF450R
The last post was made 20 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 57.07 Kb
