Rear shock adjustment on a ZZR600
chris___
PostPosted: 14:22 - 14 Jan 2006    Post subject: Rear shock adjustment on a ZZR600 Reply with quote
Ive been looking for information on how to adjust the rear shock on my ZZR600 (its to soft at the moment). In the manual it says to "take to your kawasaki dealer" Middle Finger Ive read that there is only pre-load adjustment on the shock, which is what I need to do but I dont actually knw how its done Confused Any help much appreciated! Thumbs Up
Chris
Yamaha rxs100 > Kawasaki ZZR600 > Kawasaki ZX6R > Honda Hornet 600 > Honda Bros 400 > Suzuki SV650S K2
Bikepics page
mr.z
PostPosted: 14:27 - 14 Jan 2006    Post subject: Reply with quote
You'll need a "C"spanner, never been able to find one myself and tend to use a big pair of plumbers grip things...
You may find the suspension isn't hard enough even after puting the preload all the way up, zzr suspension is notoriously squashy...
chris___
PostPosted: 18:36 - 14 Jan 2006    Post subject: Reply with quote
Yeah I've heard that it may still be squashy. Do I nedd to take off the rear wheel to adjust it? And also waht do I turn and which way to make it harder? Embarassed Laughing
Bikepics page
Zimbo
PostPosted: 22:14 - 14 Jan 2006    Post subject: Reply with quote
You're able to adjust the spring preload, and the damping.
Spring preload - adjust the collar at the top of the spring, clockwise to make the spring pressure firmer, anticlockwise to make it softer. You'll need to undo the lock ring first, then adjust the adjuster collar, then tighten the lockring up again.
Damping - a small flat blade screw on the base of the shock. Turning it clockwise makes it firmer, anticlockwise makes it softer.
ZZR shocks tend to wear out by 20,000 miles, if yours is high mileage it may be worth investing in a new one. Hagon do a good one for around £225 - £250.
The last post was made 20 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 41.09 Kb
