The Tail Swinger
ISLAND GIRL
PostPosted: 23:26 - 14 Jan 2006    Post subject: The Tail Swinger Reply with quote
Check this out for all those who struggle turning your bike around:
https://www.cyoma.com/index.htm
Require sound on too ok Thumbs Up
Live on the Isle of Wight and ride a CBR600F
mr.z
PostPosted: 23:40 - 14 Jan 2006    Post subject: Reply with quote
If your bike has a sidestand....
Put the stand down (solid ground or otherwise) pull it towards you (from the same side as the stand) and then haul it arround, spinning it on the stand (180º isn't difficult once you've practiced bit)
If i can do it with a 250kg cx then normal people bikes should be doable too
can be very usefull but dont do it too often cause its probably not good for the stand..
garry
PostPosted: 23:50 - 14 Jan 2006    Post subject: sidestand swivvle Reply with quote
my mate does that all the time, i know cos its me who welds the bracket back to the frame Thumbs Down Thumbs Down Thumbs Down
so long so long so long and thanks for all the fish !
0ni
PostPosted: 00:37 - 15 Jan 2006    Post subject: Reply with quote
I've used the trick mr.z uses for the last year on the same back. Stand till intact.
The higher the bike sits the easier it is to do. You are forcing the back wheel off the ground and using the stand as a pivot point.
Its a lovely day, just wait until some bastard spoils it.
extreme3d
PostPosted: 16:18 - 15 Jan 2006    Post subject: Reply with quote
I can't help but imagine the rear wheel skipping out from under you and the whole lot crashing down Shocked
jonnay
PostPosted: 17:04 - 15 Jan 2006    Post subject: Reply with quote
Cheaper way (in the short term Laughing ) Would be front brake on, apply power and release clutch, then just walk it round... Wink
May leave a few black lines on the garage floor though...
Jon
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
stuartevans
PostPosted: 17:06 - 15 Jan 2006    Post subject: Reply with quote
i was hooked on the little device untill i saw $89 thats about £45
you can make one yourself for less. 4 caster wheels, bit of mdf -> sorted under £10
Whosthedaddy
PostPosted: 17:07 - 15 Jan 2006    Post subject: Reply with quote
Cool idea Thumbs Up
Fecking expensive for what it does Thumbs Down
The last post was made 20 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 56.53 Kb
