Getting slower with age
Whosthedaddy
PostPosted: 17:23 - 15 Jan 2006    Post subject: Getting slower with age Reply with quote
My ZXR according to the figures in 1991 (when new) has 100 bhp, will do 0-60mph in 3 secs and top out at 150mph
Now the bike is 15 years old, it doesn't feel this spritely Sad
How much power do you think a bike loses as it gets older? How can this power be reclaimed?
base
PostPosted: 17:33 - 15 Jan 2006    Post subject: Reply with quote
i also have zxr H2 and all i can say if it does not feel rapid something is wrong maybe you need to rev it a little more, by any standards in my opinion they are quick bits of kit, i dont know what has been done to your bike but a good quality aftermarket exhaust and dyno jet kit will make a difference, and i cannot seee any reason why if it made 100bhp 15 years ago why it should not be making that now, unless its a ill little puppy
kb-zxr
PostPosted: 17:34 - 15 Jan 2006    Post subject: Reply with quote
150mph? I would have thought it was higher, as the 400s aren't far off that. I would have guessed at a good 160-165mph by looking at other 750s.
Whosthedaddy
PostPosted: 17:38 - 15 Jan 2006    Post subject: Reply with quote
Am not up to trying these speeds just yet.
I drive a fast car, so am not sure whether perception of speed has been altered slightly?
I must learn to twist the throttle gently as keep smashing knackers into gas tank when changing up at speed Shocked
WR450_geezer
Nobody likes me
PostPosted: 17:39 - 15 Jan 2006    Post subject: Reply with quote
On TopGear they did the test with old super cars and I think they were around 30-40 years old and they were originally around 200bhp but through the years and to the present day one of them had lost something stupid like 100bhp!
WR
Siggi, ''Fack, having Daz around is like living next door to PC-World, with a hole in the wall.''
base
PostPosted: 17:41 - 15 Jan 2006    Post subject: Reply with quote
yes this is true top gear did show some had lost loads of BHP but they did run like utter dogs
kb-zxr
PostPosted: 17:49 - 15 Jan 2006    Post subject: Reply with quote
That speed may be right though, I was just thinking out loud really.
To stop smacking yer nads on the tank grip the tank with your knees/thighs. Helps a bit, but pot holes still hurt Crying or Very sad
Damn Showas Razz Must be a ZXR thing
mchaggis
PostPosted: 17:54 - 15 Jan 2006    Post subject: Reply with quote
Bearing wear, camchain wear ('lengthened' chain means dodgy cam timing), worn cams/ followers, worn valve seats (loss of compression) and springs, worn piston rings + bores (increased slap and blowby), worn clutches, worn pretty much everything.
To regain lost power, renew everything which is worn, which includes a rebore and new pistons, new plugs, new cams, valves, cleaned ports, new bearings, etc etc etc. Hell a new radiator might even help things.
I must not be a troll...
Mmmm, Guinness
Barry_M2
PostPosted: 17:57 - 15 Jan 2006    Post subject: Reply with quote
Car wont have anything to do with it, I have a fast car and its completley different to riding a bike fast, you should know that!
My ZXR750 feels plenty fast enough, although it has had a recent engine rebuild and a set of Kent fast road cams.
Silver
PostPosted: 18:01 - 15 Jan 2006    Post subject: Reply with quote
Doubt it. I had a ZXR750 J1 and went to a ZX6R (636cc model) and the smaller bike was much faster everywhere.
loply
PostPosted: 18:02 - 15 Jan 2006    Post subject: Reply with quote
Might be worth getting the bike dynoed, its not unusual to have problems with a bike that result in a large loss of power.
Wasnt there somebody on here who had a Triumph that was giving out 80bhp when it should have made 110 or something?
Yamaha SZR660 Caution to the wind, the throttle pinned!
Type_Mo
PostPosted: 18:21 - 15 Jan 2006    Post subject: Reply with quote
I thoguht engines get a little quicker as they do more milage.
but then the engine could be getting clogged with carbon deposits or whatever.
or maybe your soo used to the bike it feels slow?
mchaggis
PostPosted: 18:29 - 15 Jan 2006    Post subject: Reply with quote
Producing a lot of power from a small capacity (i.e. most bike engines) requires very fine physical tolerances and (sort of) precise gas flow. Upset the gas flow with deposits, worn valves and retarded cam timing and the torque production won't be quite as high. Sloppiness and increased clearances between parts will limit the rev range to some extent too.
Mmmm, Guinness
oldgit
PostPosted: 16:52 - 18 Jan 2006    Post subject: Reply with quote
I've got a GPX750 (basically the same engine as the ZXR, but only 106bhp) which has done just over 50,000 miles. A GPX750 was tested by Bike in 1987 with a top speed of just over 150 and it did the quarter mile in 11.5 seconds with a terminal speed of 120. I took mine on the Bulldog run what u brung and even with me riding it did 11.8sec and 117mph, so I don't think it's significantly down on power.
The ZXR develops slightly more power (112) and is 8Kg heavier, so it should produce more or less the same figures - the 1/4 mile time was supposed to be 11.3.
Things like carb balancing, dirty air filter, worn spark plugs, dodgy leads, valve adjustment, dry drive chain etc. can reduce power by quite a lot.
grumpy old man
Visitor Q
$25 whore
PostPosted: 18:12 - 18 Jan 2006    Post subject: Reply with quote
I would imagine a 1980s RGV250 without any miles on it makes the same power now as it did then.
Its mileage and wear.
Im experiencing something similar to this with the smod.
PostPosted: 18:28 - 18 Jan 2006    Post subject: Reply with quote
Wear and servicing will affect it. In addition to what was mentioned above, the drive chain is probably past its best, eating a bit of power, air filter in need of replacement, jetting is probably miles out from wear to the attomiser tubes (and probably someone fitting a race can in the past and not setting it up right), carbs out of balance, wheel bearings are probably past their best, airbox not sealing to the carbs, double bubble screen making the bike taller at the front, brakes dragging a touch, coked up exhaust, etc.
Even really silly things might have an effect. Throttle cable for example. If it is getting old then it will take more effort to open the throttle, which subconciously will make the bike feel slower.
Also, not sure how much experience you have, but to produce that kind of performance the bike needs to be thrashed on full throttle at the red line, rather than half throttle at the red line or full throttle and changing up at 7000rpm (both common).
Realistically they are 15~25mph off that. An FZR1000 from the early 1990s would manage mid 160s.
R6jonny
PostPosted: 19:47 - 18 Jan 2006    Post subject: Reply with quote
mchaggis wrote:
(increased slap and blowby).
Oooooooh sounds kinky
Honda NSR125 - Yamaha R6 - Ducati 748 - Suzuki GSXR750K6/GSXR1000K7/GSXR750K8 - Ducati 848 - Honda SP1 - Triumph Daytona 675
"simply because she is a female and is thus her actions largely make no sense whatsoever by default"
The last post was made 20 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 98.41 Kb
